Browse Forums Building A New House Re: Metricon Winchester 28- Landscaping 1263Jan 14, 2019 9:17 am Our Bayside KDR Thread: viewtopic.php?f=31&t=78298 Re: Metricon Winchester 28- Landscaping 1264Jan 14, 2019 9:18 am Just the standard small black handle with lock Re: Metricon Winchester 28- Landscaping 1265Jan 14, 2019 9:23 am what does your contract say? ours has this wording, and specifies 'back to back'... for $720 we had better be getting two handles!! 51. Provide Doric DN197 Offset stainless steel 425mm long back to back rectangular pull handles (HDL040) with Lockwood Optimum double cylinder keyed mortice lock (LCK052) to Southern Star 300 Series (Wide Stile) aluminium door(s) in lieu of standard Doric Wilton internal snib door furniture. Note: This item is only available with Southern Star 300WS Wide Stile Series aluminium sliding or stacker doors. This item is not suitable with the inclusion of a flydoor. Extra Description: Location: Dining (W5) Re: Metricon Winchester 28- Landscaping 1266Jan 14, 2019 9:26 am shokel1975 what does your contract say? ours has this wording, and specifies 'back to back'... for $720 we had better be getting two handles!! 51. Provide Doric DN197 Offset stainless steel 425mm long back to back rectangular pull handles (HDL040) with Lockwood Optimum double cylinder keyed mortice lock (LCK052) to Southern Star 300 Series (Wide Stile) aluminium door(s) in lieu of standard Doric Wilton internal snib door furniture. Note: This item is only available with Southern Star 300WS Wide Stile Series aluminium sliding or stacker doors. This item is not suitable with the inclusion of a flydoor. Extra Description: Location: Dining (W5) Re: Metricon Winchester 28- Landscaping 1267Jan 14, 2019 10:03 am shokel1975 what does your contract say? ours has this wording, and specifies 'back to back'... for $720 we had better be getting two handles!! 51. Provide Doric DN197 Offset stainless steel 425mm long back to back rectangular pull handles (HDL040) with Lockwood Optimum double cylinder keyed mortice lock (LCK052) to Southern Star 300 Series (Wide Stile) aluminium door(s) in lieu of standard Doric Wilton internal snib door furniture. Note: This item is only available with Southern Star 300WS Wide Stile Series aluminium sliding or stacker doors. This item is not suitable with the inclusion of a flydoor. Extra Description: Location: Dining (W5) Contract shows both sides: Provide Star Range door furniture - Delta in lieu of standard including: * (2No) Double lock set with internal and external cylinders. Note: This item is available to Aluminium/timber sliding, biparting & stacker doors only. Re: Metricon Winchester 28- Landscaping 1268Jan 14, 2019 10:33 am blackcat20 shokel1975 what does your contract say? ours has this wording, and specifies 'back to back'... for $720 we had better be getting two handles!! 51. Provide Doric DN197 Offset stainless steel 425mm long back to back rectangular pull handles (HDL040) with Lockwood Optimum double cylinder keyed mortice lock (LCK052) to Southern Star 300 Series (Wide Stile) aluminium door(s) in lieu of standard Doric Wilton internal snib door furniture. Note: This item is only available with Southern Star 300WS Wide Stile Series aluminium sliding or stacker doors. This item is not suitable with the inclusion of a flydoor. Extra Description: Location: Dining (W5) Contract shows both sides: Provide Star Range door furniture - Delta in lieu of standard including: * (2No) Double lock set with internal and external cylinders. Note: This item is available to Aluminium/timber sliding, biparting & stacker doors only. I think this description is for the standard handle, the cost is for the lock. We have this one with the same wording for our bedroom balcony slider. Are your handles different on each side of the door? Do you have pics? Re: Metricon Winchester 28- Landscaping 1269Jan 14, 2019 10:36 am shokel1975 blackcat20 shokel1975 what does your contract say? ours has this wording, and specifies 'back to back'... for $720 we had better be getting two handles!! 51. Provide Doric DN197 Offset stainless steel 425mm long back to back rectangular pull handles (HDL040) with Lockwood Optimum double cylinder keyed mortice lock (LCK052) to Southern Star 300 Series (Wide Stile) aluminium door(s) in lieu of standard Doric Wilton internal snib door furniture. Note: This item is only available with Southern Star 300WS Wide Stile Series aluminium sliding or stacker doors. This item is not suitable with the inclusion of a flydoor. Extra Description: Location: Dining (W5) Contract shows both sides: Provide Star Range door furniture - Delta in lieu of standard including: * (2No) Double lock set with internal and external cylinders. Note: This item is available to Aluminium/timber sliding, biparting & stacker doors only. I think this description is for the standard handle, the cost is for the lock. We have this one with the same wording for our bedroom balcony slider. Are your handles different on each side of the door? Do you have pics? No, this is the upgraded handle, there is a separate line for the delection of the original. It clearly says double (in lieu of standard), internal and external. This is the handle: https://www.windowsanddoors.build/Produ ... elta1.aspx No pic as I'm at work but the external handle is the standard one. We left the laundry as standard and it states Alpha door furniture, so clearly different. Re: Metricon Winchester 28- Landscaping 1270Jan 14, 2019 11:42 am Ok, that makes sense. Def follow M up - who on earth would install two different handles on the one door?? Re: Metricon Winchester 28- Landscaping 1271Jan 14, 2019 12:18 pm blackcat20 shokel1975 blackcat20 [quote="shokel1975"]what does your contract say? ours has this wording, and specifies 'back to back'... for $720 we had better be getting two handles!! 51. Provide Doric DN197 Offset stainless steel 425mm long back to back rectangular pull handles (HDL040) with Lockwood Optimum double cylinder keyed mortice lock (LCK052) to Southern Star 300 Series (Wide Stile) aluminium door(s) in lieu of standard Doric Wilton internal snib door furniture. Note: This item is only available with Southern Star 300WS Wide Stile Series aluminium sliding or stacker doors. This item is not suitable with the inclusion of a flydoor. Extra Description: Location: Dining (W5) Contract shows both sides: Provide Star Range door furniture - Delta in lieu of standard including: * (2No) Double lock set with internal and external cylinders. Note: This item is available to Aluminium/timber sliding, biparting & stacker doors only. I think this description is for the standard handle, the cost is for the lock. We have this one with the same wording for our bedroom balcony slider. Are your handles different on each side of the door? Do you have pics? No, this is the upgraded handle, there is a separate line for the delection of the original. It clearly says double (in lieu of standard), internal and external. This is the handle: https://www.windowsanddoors.build/Produ ... elta1.aspx No pic as I'm at work but the external handle is the standard one. We left the laundry as standard and it states Alpha door furniture, so clearly different.[/quote]We have that handle inside, but the other part outside... Our Bayside KDR Thread: viewtopic.php?f=31&t=78298 Re: Metricon Winchester 28- Landscaping 1272Jan 14, 2019 1:22 pm Drew01 We have that handle inside, but the other part outside... Doesnt quite make sense when the paper work says 2, internal/external. Re: Metricon Winchester 28- Landscaping 1273Jan 14, 2019 1:36 pm blackcat20 Drew01 We have that handle inside, but the other part outside... Doesnt quite make sense when the paper work says 2, internal/external. Our Bayside KDR Thread: viewtopic.php?f=31&t=78298 Re: Metricon Winchester 28- Landscaping 1274Jan 20, 2019 3:57 pm Re: Metricon Winchester 28- Landscaping 1275Jan 21, 2019 11:24 am blackcat20 excited_builders Thanks ...so the swap was done post handover.... https://r.tapatalk.com/shareLink?url=ht ... are_type=t Yes, a few weeks after we moved in. https://r.tapatalk.com/shareLink?url=ht ... are_type=t Re: Metricon Winchester 28- Landscaping 1276Jan 21, 2019 3:51 pm Our Bayside KDR Thread: viewtopic.php?f=31&t=78298 Re: Metricon Winchester 28- Landscaping 1277Jan 21, 2019 4:51 pm Drew01 blackcat20 Drew01 We have that handle inside, but the other part outside... Doesnt quite make sense when the paper work says 2, internal/external. https://r.tapatalk.com/shareLink?url=ht ... are_type=t Re: Metricon Winchester 28- Landscaping 1278Jan 23, 2019 9:17 am excited_builders We have the handle only on the inside and the normal lock on the outside. All display homes are also similar so not sure how your contract says 2 handles for the stacker door. https://r.tapatalk.com/shareLink?url=ht ... are_type=t You've got to wonder...I certainly dont see the point of upgrading to a nice handle on the inside and leaving the cheap looking one on the outside. All systems go to finish the front yard next weekend, and get the side path started. Soil and turf deliveries booked. This is the general plan: Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Just need to find some sleepers I like for the planter under the window. Already have the timber to surround the crepe myrtle. Then need to wait a few months to pick up some bare-rooted roses for each side of the path. Re: Metricon Winchester 28- Landscaping 1279Feb 02, 2019 6:37 pm Another busy weekend Side path filled and levelled. Front dressed with soil, tree framed up and turf laid. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Metricon Winchester 28- Landscaping 1280Feb 02, 2019 7:09 pm You guys are machines!!! Our Bayside KDR Thread: viewtopic.php?f=31&t=78298 Hmmm, I have checked your past posts and it seems that you are in NSW, not WA as I had thought. It pays to show your State in your avatar. Retaining wall regulations… 5 7850 Hi, you've probably already resolved this, however, Commbank will probably pay the funds to you after you send evidence the work is done regardless the change in the quotes. 1 35321 Ideally you would engage a landscaper to give you some insight what they may need in the space to make your vision come to life… 1 13634 |
