Browse Forums Heating, Cooling & Insulation Re: Ducted reverse cycle air con, is it worth it? 3Jan 08, 2019 3:17 pm The Harder You Try - the Luckier You Get ! Web site http://www.anewhouse.com.au Informative, Amusing, and Opinionated Blog - Over 600 posts on all aspects of building a new house. Re: Ducted reverse cycle air con, is it worth it? 4Jan 09, 2019 5:52 pm bashworth We have had reverse cycle split systems in our last three houses. Effective cooling and inexpensive heating in winter (cheaper than gas) we wouldn't have any other system In our last house we had a whole house system but in our current 2 bedroom retirement unit we have got 2 separate units. One in our living dining area and a 2nd in our bedroom. We have a split system in our current house... which is approx 24 squares & it doesn't reach our bedroom. Don't really want to put another one in this house. Our next house will be approx 30-35 squares. I just don't want to have to have multiple split systems throughout the house Re: Ducted reverse cycle air con, is it worth it? 5Jan 09, 2019 6:24 pm Multi-splits are much more efficient than zoned ducted systems, easier to install too, save some roof and storage space (if double storey). Multi-split units can also be ducted (e.g. in bulk heads) or cassette (integrated into ceiling) too. Re: Ducted reverse cycle air con, is it worth it? 6Jan 09, 2019 6:28 pm We have a ducted refrigerated system (cooling & heating) in our KDRB house which is 42 sq 2 storey and we think it was the best money we spent in the build. When we built in 2016 the 22kw Brivis system was $16.9k with 15 outlets. If you are building 2 storey, you won’t regret going ducted refrigerated. Our build thread viewtopic.php?f=31&t=82369&p=1525857&hilit=fairhaven#p1525857 Re: Ducted reverse cycle air con, is it worth it? 8Jan 13, 2019 9:12 am We are doing multiple splits in ours again thought mostly used for cooling here in qld. Will have 1 in kids wing, 1 in living area, and will install one in master and probably media after we move in. Re: Ducted reverse cycle air con, is it worth it? 9Aug 21, 2019 3:40 pm Is the ducted reverse cycle include heating and cooling and both uses electricity? Does it heat the house effectively? We have ducted gas heating and it does warm the house effectively. In our second build, we are thinking to go for electric ducted heating and cooling. We are in the process of building a double storey home so definitely need to have it included in our build. Thanks Re: Ducted reverse cycle air con, is it worth it? 10Sep 13, 2019 2:11 am I was going to duct the reverse cycle air con installed but I refused in the last moment. Re: Ducted reverse cycle air con, is it worth it? 11Sep 13, 2019 4:46 am alexsandro13 I was going to duct the reverse cycle air con installed but I refused in the last moment. Why is that? We are thinking to go for ducted reverse cycle heating and cooling as we don't prefer gas heating and planning to install solar panels after hand over. Hi all, sorting out the ducted air con for a 350sqm double story house. Does this placement sound reasonable to you? Also, I plan to have 6 zones I think. Living room… 0 0 Hi all, sorting out the ducted air con for a 350sqm double story house. I think i plan to have 6 zones I think. Living room (mainly for entertainment so not used often),… 0 0 0 6295 |
