Browse Forums Building A New House Re: Our Bordeaux 56 Build in Sydney 69Jan 22, 2019 11:38 pm nvl93 Hi Rajat, Thanks for that. We're in the final stages of tender for request and and we ended up with an estimate of a whopping $1,045,941 haha. That included the spiral staircase (58k), Hebel floor (24k), balcony (30k), changes to floor plan (15k) and heaps more. Yeah our consultant is pushing to put an authority through for the display door to be included as standard in our build. Hopefully it goes through! Anyways i will be following your build and wish you the best. Any update on your 56a build ? Are you able to share your 2D plans ? I am looking to build the 56a in Brisbane Re: Our Bordeaux 56 Build in Sydney 70Jan 23, 2019 5:55 am paddycc nvl93 Hi Rajat, Thanks for that. We're in the final stages of tender for request and and we ended up with an estimate of a whopping $1,045,941 haha. That included the spiral staircase (58k), Hebel floor (24k), balcony (30k), changes to floor plan (15k) and heaps more. Yeah our consultant is pushing to put an authority through for the display door to be included as standard in our build. Hopefully it goes through! Anyways i will be following your build and wish you the best. Any update on your 56a build ? Are you able to share your 2D plans ? I am looking to build the 56a in Brisbane There really hasn’t been any update since early December. Only the front door handle and locks have been installed. I think the tradies are only now coming back to work so hopefully there will be some profress in the coming weeks. Our plan is Bordeaux56, rather than Bordeaux56a. The names are similar, but the plans are completely different. The 56A has the spiral stairs in the middle of the house, which completely changes the plans. Below are the standard Bordeaux 56 and 56a plans respectively from Metricon website. Bordeaux 56 (ground floor and first floor): Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Bordeaux 56A (ground floor and first floor): Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ The 2D plans of our Bordeaux 56 are there in earlier posts, but if you still need them then I will send to you. Re: Our Bordeaux 56 Build in Sydney 71Jan 23, 2019 9:05 am rajat paddycc nvl93 Hi Rajat, Thanks for that. We're in the final stages of tender for request and and we ended up with an estimate of a whopping $1,045,941 haha. That included the spiral staircase (58k), Hebel floor (24k), balcony (30k), changes to floor plan (15k) and heaps more. Yeah our consultant is pushing to put an authority through for the display door to be included as standard in our build. Hopefully it goes through! Anyways i will be following your build and wish you the best. Any update on your 56a build ? Are you able to share your 2D plans ? I am looking to build the 56a in Brisbane There really hasn’t been any update since early December. Only the front door handle and locks have been installed. I think the tradies are only now coming back to work so hopefully there will be some profress in the coming weeks. Our plan is Bordeaux56, rather than Bordeaux56a. The names are similar, but the plans are completely different. The 56A has the spiral stairs in the middle of the house, which completely changes the plans. Below are the standard Bordeaux 56 and 56a plans respectively from Metricon website. Bordeaux 56 (ground floor and first floor): Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Bordeaux 56A (ground floor and first floor): Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ The 2D plans of our Bordeaux 56 are there in earlier posts, but if you still need them then I will send to you. Thanks for this. Yes I have these off the website, but I noticed someone in the thread was starting a 56A build. I am looking at building the 56A in Brisbane. My family are in the building industry and Metricon won't release the 56A plans, so I was wondering if anyone had the standard plans so I could see window opening measurements etc. What I was thinking was getting Metricon to build to lock up stage and then have my family business fitout after that...not sure if they will do that but those are my thoughts. Your house looks amazing ! I am just trying to do my build for as little cost possible but still have the amazing Bordeaux 56A design Re: Our Bordeaux 56 Build in Sydney 72Mar 01, 2019 1:15 pm Hi Rajat, You might want to check your inclusions list as I noticed your front entry frame does not have the aluminium enviroseal on the bottom. This will stop the draft getting in. I had the same issue and made them replace the frame after handover. Re: Our Bordeaux 56 Build in Sydney 73Mar 01, 2019 6:19 pm Re: Our Bordeaux 56 Build in Sydney 75Dec 07, 2019 1:22 pm Handed over from Metricon....finally
We are busy doing the landscaping.....waiting for council to approve some retaining wall plans, but we are going to move in next week. Just finished driveway last month. Will share new pics shortly.... Metricon took sooooo long to handover....House inspect (private inspector that we hired) found lots of things to be fixed, which took some time to fix. Another month or so delayed because Metricon couldn't get the correct size ducting for the exhaust for the gas cooktop. Anyway, all handed over now Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Our Bordeaux 56 Build in Sydney 76Dec 07, 2019 1:30 pm vuster Hi Rajat, You might want to check your inclusions list as I noticed your front entry frame does not have the aluminium enviroseal on the bottom. This will stop the draft getting in. I had the same issue and made them replace the frame after handover. Hi Vuster, In the basix, they had mentioned that owner has to install weather seal after handover... Re: Our Bordeaux 56 Build in Sydney 77Dec 13, 2019 8:08 am Congratulations!! It looks great from the front -- any photos from inside before you move in? Re: Our Bordeaux 56 Build in Sydney 79Feb 19, 2020 5:12 pm nab Hi I just wanted to know, do you k ow the supplier for the wrought iron window balustrade? Hi Nab, sorry, I don’t know who supplied those wrought iron balustrades. If I do find out, I will let you know Re: Our Bordeaux 56 Build in Sydney 80Aug 05, 2020 2:23 am Congrats Rajat on your beautiful home. Incase anyone sees this message, would you happen to know please what interior colours were used in the SYDNEY Bordeaux display home for: - internal wall paint - kitchen cabinets Thanks so much in advance! Thank you so much everyone. This all makes a lot of sense. I guess when you talk to a builder who butters up everything to look very polished, you get to start believing… 7 17581 Hi I live in a 100yr old semi and my neighbour added an additional floor last yr and our architect has advised that we can knock down our semi and build a free-standing… 0 37693 Hi all, We are looking to build a new two storey house in western Sydney. Can anyone recommend a smallish builder to go with? We are trying to stay away from the big… 0 12138 |
