Browse Forums Safer Living Re: Recommend security cameras + supporting system 2Jan 02, 2019 7:08 am Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog Re: Recommend security cameras + supporting system 8Jan 03, 2019 12:51 pm IamSAM Most of the cheap camera models are not vari focus and do not support H.265. Thus during install they cannot be 'custom' setup. Many NVR have limited incoming bandwidth. Many NVR do not support ONVIF and H.265 You will be surprised, but most of them do. In fact, it is harder to find the ones which DO NOT. Re: Recommend security cameras + supporting system 10Feb 24, 2020 9:44 am The software will allow you to control the NVR fan, however it is best left to the default. The fan and the storage hard disk are behind the inevitable hum. Re: Recommend security cameras + supporting system 11Apr 28, 2021 10:37 am If the fan making a noise is still an issue Dahua offers a recorder that's fan-less (NVR2108-8P-4KS2), but I recommend not installing that recorder somewhere that's not well ventilated since you don't want to over-heat it and have it build to much dust which can cause problems in the future. TRANTECH SECURITY WHOLESALER 26 Davies Ave, Sunshine North VIC 3020 T: (02) 8722 0348 (Syd) T: (03) 9079 5566 (Mel) www.trantechsecurity.com.au It's all about wireless, self install now. The cost/benefit of wired setups for the house are no longer what they used to be. Lots of wireless options. Eufy, Arlo and… 2 10444 Hi When it rains in a particular direction water comes through the security door. It hits the main door and the bottom swells and jams. There is already a cover over the… 0 38808 You have no photo with your post. Best I can say is to remove an A&L flyscreen don't be afraid to distort the frame almost like a trapezium. It doesn't take a lot of… 1 7468 |
