Browse Forums Owner Builder Forum Re: Fixing particle board to steel sub floor 2Dec 17, 2018 7:29 am Highlander Hi, i'm OB'ing a steel frame home, the floor (Stratco) is almost up & ready to add floor boards. Obviously i can't use a nail gun, just wondering what method people are using, will the boards be soft enough to allow a screw to be driven in flush, am i using glue as you would with timber ? Also what thickness is ideal & is it worth paint under side before installing ? Cheers All sorted lol Hi I am wanting some opinions about the build of a steel shed I am going to get one about 4.5 x 2.5 m steel shed and the height will be about 2.3-2.4m high The one I am… 0 14952 Building Standards; Getting It Right! 1. optional, you can but normally just use the earth from the main switch board 2. should be enough but the distance determines voltage drop - sparky should work it… 1 29432 I'll look into different shower heads and ask the plumber about some engineering and see what he says. Thanks 2 10262 |
