Browse Forums Windows & Doors Re: Double glazing 9Nov 28, 2018 4:19 pm arcadelt So let me get this right - you have one pane of 4mm glass and another of 6.5mm glass. How big is the gap between? Double-glazing for noise is better when there is a bigger gap, but a smaller gaps for temperature insulation. They said there is only a 6.5mm gap now would this be worth $2000 in your opinion Re: Double glazing 10Nov 28, 2018 4:50 pm arcadelt So let me get this right - you have one pane of 4mm glass and another of 6.5mm glass. How big is the gap between? Double-glazing for noise is better when there is a bigger gap, but a smaller gaps for temperature insulation. It's toughness glass 4mm thick both sides with an 8 mm gap between the double glazing Re: Double glazing 13Nov 28, 2018 5:17 pm arcadelt Andy7575 It's toughness glass 4mm thick both sides with an 8 mm gap between the double glazing So what was the reference to "with 6.5mm hap hush glass" in the original post? I meant 6.5 mm hush glass with 4 mm toughened glass they said they fitted acoustics to it and they said the problem of the noise coming in thru the weep holes which they are fixing Friday 8 mm gap between double glazing Re: Double glazing 14Nov 28, 2018 5:35 pm Andy7575 arcadelt Andy7575 It's toughness glass 4mm thick both sides with an 8 mm gap between the double glazing So what was the reference to "with 6.5mm hap hush glass" in the original post? I meant 6.5 mm hush glass with 4 mm toughened glass they said they fitted acoustics to it and they said the problem of the noise coming in thru the weep holes which they are fixing Friday 8 mm gap between double and how can you tell if you have acoustic glass or notglazing Re: Double glazing 15Dec 03, 2018 3:23 pm Andy7575 I had double glazing put in because I live behind noisy shops they put in 4mm toughened glass with 6.5mm hap hush glass should this reduce noise or was it a complete waste of money $2000 do you think I should take them to consumer protection thanks If you have it in writing that this would reduce your noise problem, it is their problem and you should expect a result. But it is quite likely that noise was coming into your home from other places too, like walls, the ceiling and gaps between the window and house frame. The thickness of the glass makes the biggest difference. The gap is almost irrelevant (yes, I know what they say). Similarly, laminated glass makes a small difference only. Ed "ECOECO" At 'EcoEco', we design windows, we design the best windows, we do it for you, so that when you’re happy we are happy. Tel. 1800 326 326 Re: Double glazing 17Apr 24, 2019 7:06 pm sophie123 that would depend on the specs upon order placement, I had the same issue when ordering mine, I wanted a decent Rw rating to reduce as much noise as possible (I'm a light sleeper) so went through all the variable glass widths and gas space widths. My only problem now is to prove the Rw reduction which was claimed and paid for. Re: Double glazing 18Apr 26, 2019 10:59 am Our windows are all laboratory tested... our standard double glazed window achieves Rw 35 and this can be upgraded to Rw 39. These have been placed in projects with acoustic engineers reports which specify the likes of 12.38mm & 10.38mm glass, and have been measured in situ by the engineers and achieve the test results. Glass is part of the solution, well designed, well-sealed windows are the other part. Without a test certificate, you really don't know what the result will be. BTW our standard aluminium window is also the most energy efficient aluminium window in Australia... and carries a wind rating of N4 for an awning window, 2400 x 2400... My guess is we will be 30% cheaper than any equivalent window. "ECOECO" At 'EcoEco', we design windows, we design the best windows, we do it for you, so that when you’re happy we are happy. Tel. 1800 326 326 Re: Double glazing 19Jun 04, 2019 3:03 pm ECOECO Our windows are all laboratory tested... our standard double glazed window achieves Rw 35 and this can be upgraded to Rw 39. These have been placed in projects with acoustic engineers reports which specify the likes of 12.38mm & 10.38mm glass, and have been measured in situ by the engineers and achieve the test results. Glass is part of the solution, well designed, well-sealed windows are the other part. Without a test certificate, you really don't know what the result will be. BTW our standard aluminium window is also the most energy efficient aluminium window in Australia... and carries a wind rating of N4 for an awning window, 2400 x 2400... My guess is we will be 30% cheaper than any equivalent window. hey mate, do you have any suppliers in sydney that you could recommend for double glazing? -Rob Re: Double glazing 20Jun 04, 2019 6:13 pm Hi Sorry I don't recommend in Sydney, I am not up to date with the Sydney market. Thanks Ed "ECOECO" At 'EcoEco', we design windows, we design the best windows, we do it for you, so that when you’re happy we are happy. Tel. 1800 326 326 This is one of the reasons I decided to go overseas for my double glazed windows. As the builder indicated, he's worked on many upmarket builds, these were the most well… 13 19409 For your reference Performance Labels: Window assemblies in housing, except timber windows, must be labelled so the label can be seen when it is in situ. For timber… 6 9402 I’m in a similar position except I’m after sliding 3 stacking doors. I am on a second-story apartment of which the balcony would not adequately fit any bi-fold or… 5 16336 |
