Browse Forums Building Standards; Getting It Right! Re: Plumbing query / standard 2Nov 10, 2018 7:16 pm 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Plumbing query / standard 4Nov 13, 2018 5:45 pm 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Plumbing query / standard 7Nov 20, 2018 7:28 am 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Plumbing query / standard 8Nov 20, 2018 5:41 pm simonsss Many thanks for the reply, however they were advised this is a charged system for rain water tanks above ground at the start of the build, and appears the pipes move around so not sealed. This is what the other 8 down pipes look like. This is the workmanship to date. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Been over 5 months like this. Caused much damage to slab? Yes it will cause slab heave,that is not good enough. Looks like you are in Rockbank,Melton or Cobblebank? 2 7203 There is no reason why building contract reconciliation cannot be done prior to handover, if the builder won't do it get someone to do it for you. Why would you pay for… 3 6690 In my experience roof is essential element of the building envelope and hence a common property and should be covered by owners corporation however a detailed review of… 3 6172 |
