Browse Forums Building A New House Re: Coral Homes Daydream 28 Far North Coast NSW 93Nov 19, 2018 7:23 pm Hi Gareth, The early stages seem to happen very quickly. Progress seems to slow down after lock-up. I hope they allow enough time for your slab to cure before installing wall frames. Not saying that it is going to happen to you but keep an eye out for the edge of the slab crumbling when they drill into the slab to fix tie rods. A couple building with Coral near me had the edge of their slab blown out in half a dozen or so places when holes for tie rods were drilled. They pointed the broken bits out to their SS. The problem was fixed by filling the broken edges with a resin. Hope it doesn't happen to you but just keep an eye on it. Cheers. Brad Re: Coral Homes Daydream 28 Far North Coast NSW 95Nov 27, 2018 2:17 pm Hi Tash, I have been a bit busy over the past couple of weeks and haven't had time to update my progress posts....... yes frames are up and they started putting on the fascias and gutters today with roofing to start this week also. It is not critical that noggins are level and it is pretty common for noggin to be inexact / skewed in its placement. So long as the frames are square and not warped. We have a couple of rough bits in ours as well but the chippies were back there this morning so I am yet to see whether they have completed the incomplete bits and fixed the couple of rough bits. I will check on my way home this afternoon. If you are concerned about how your frames are looking request a walk through with your SS. Cheers, Brad Re: Coral Homes Daydream 28 Far North Coast NSW 99Nov 30, 2018 10:20 am radford Hi wondering has anyone built with Andenbrook homes ballina Hi radford, try searching username GoodeOne; topic RE: Adenbrook Homes Ballina - Bricks Near Completion! Re: Coral Homes Daydream 28 Far North Coast NSW 100Nov 30, 2018 10:27 am Brad_2477 radford Hi wondering has anyone built with Andenbrook homes ballina Hi radford, try searching username GoodeOne; topic RE: Adenbrook Homes Ballina - Bricks Near Completion! Thanks Brad, we have looked at Coral and like the plans they have . We have received a estimate on a grange 25. Enjoyed reading your post very helpful. Anybody know any good and reasonably priced Air conditioning contractors/companies that could install a ducted air conditioning system in the Central Coast NSW for a small… 0 8996 Petercurtis You able to contact the certifier and get a copy of your structural plans, if they are not in your contract. If your home was approved via CDC then they… 1 20185 The OP has gone The latch and striker are definitely not aligned but there was no point trying to help the OP understand that. Hence the reason they are no longer with us. 12 5695 |
