Browse Forums Windows & Doors Re: Window height in upper level -looks like stuffed up 6Nov 15, 2018 12:56 pm Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Here is the window 10-18 size. The framer told that the top portion to the window (above window) it would around 300mm. So it works that window would be 1250mm AFL as the height of the window is 1000mm. It looks too high visually, however, considering the measurements it should not be too high? Re: Window height in upper level -looks like stuffed up 9Nov 15, 2018 3:32 pm Clean Thanks gillybean. feels better now. My personal opinion is that there’s way too much emphasis put on bedrooms having lots of natural light. Every lifestyle show on tv it seems has people going into bedrooms and gushing over “look how much natural light is in the bedroom”. I just want to shake them at times and say you do realise they’re primarily for sleeping in during the night time, yeah? 😂 Thank you. Do I use timber floorboards for stairs or do people use timber treads? Or is both the same? 6 7620 2 1033 No the fireplace doesn’t work. It’s been enclosed. I’m not sure what was removed, as it was done quite some time ago - well before what I can see with photos online… 2 11806 |
