Oh boy.... and we are trusting these guys to build our houses???
Browse Forums Building A New House Re: Metricon Winchester 28- Keys! 1143Nov 14, 2018 8:22 am blackcat20 Forgot to mention the resolution regarding the HPM versus Clipsal power point issue. It was raised at PCI, then discussed again at handover. The office has confirmed we should have Clipsal as per our contract and electrical plans, but for some reason this didnt happen (the order sheet also shows Clipsal). So arrangements will be made for everything to be swapped over. As far as I understand this includes the switchboard. So they will switch to Clipsal? After handover? Re: Metricon Winchester 28- Keys! 1144Nov 14, 2018 8:26 am Kimmykim blackcat20 Forgot to mention the resolution regarding the HPM versus Clipsal power point issue. It was raised at PCI, then discussed again at handover. The office has confirmed we should have Clipsal as per our contract and electrical plans, but for some reason this didnt happen (the order sheet also shows Clipsal). So arrangements will be made for everything to be swapped over. As far as I understand this includes the switchboard. So they will switch to Clipsal? After handover? Yes, its essentially a defect as its not per contract so theyll send someone out to swap them over. Re: Metricon Winchester 28- Keys! 1145Nov 14, 2018 9:52 am blackcat20 Kimmykim blackcat20 Forgot to mention the resolution regarding the HPM versus Clipsal power point issue. It was raised at PCI, then discussed again at handover. The office has confirmed we should have Clipsal as per our contract and electrical plans, but for some reason this didnt happen (the order sheet also shows Clipsal). So arrangements will be made for everything to be swapped over. As far as I understand this includes the switchboard. So they will switch to Clipsal? After handover? Yes, its essentially a defect as its not per contract so theyll send someone out to swap them over. Our switchboard is Clipsal but not sure whether the switches are HPM or Clipsal Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Metricon Winchester 28- Keys! 1146Nov 14, 2018 9:56 am They look like HPM; do they say Legrand on the front? You might also find the switch board box is clipsal but the contents are HPM. Re: Metricon Winchester 28- Keys! 1147Nov 14, 2018 11:35 am blackcat20 They look like HPM; do they say Legrand on the front? You might also find the switch board box is clipsal but the contents are HPM. Not sure, husband went down for final inspection, I wasn't there. But he said he saw the switch outdoor switches with HPM label. I guess they are all HPM. Re: Metricon Winchester 28- Keys! 1148Nov 14, 2018 11:41 am Weren't your plans stamped to say it was home in lieu of Clipsal? Re: Metricon Winchester 28- Keys! 1149Nov 14, 2018 11:57 am blackcat20 Weren't your plans stamped to say it was home in lieu of Clipsal? Contract is Clipsal but we found out that in the building permit, it was stamped HPM. But we were not informed of the change. Re: Metricon Winchester 28- Keys! 1150Nov 14, 2018 12:00 pm Kimmykim blackcat20 Weren't your plans stamped to say it was home in lieu of Clipsal? Contract is Clipsal but we found out that in the building permit, it was stamped HPM. But we were not informed of the change. Re: Metricon Winchester 28- Keys! 1151Nov 14, 2018 12:16 pm blackcat20 Kimmykim blackcat20 Weren't your plans stamped to say it was home in lieu of Clipsal? Contract is Clipsal but we found out that in the building permit, it was stamped HPM. But we were not informed of the change. We will query them. No harm to ask. Thanks Blackcat. By the way, for the last payment, did you have to settle before or after handover? We haven't received our last invoice till today and our final inspection was 3 weeks ago! Re: Metricon Winchester 28- Keys! 1152Nov 14, 2018 12:17 pm Kimmykim blackcat20 Kimmykim [quote="blackcat20"]Weren't your plans stamped to say it was home in lieu of Clipsal? Contract is Clipsal but we found out that in the building permit, it was stamped HPM. But we were not informed of the change. We will query them. No harm to ask. Thanks Blackcat. By the way, for the last payment, did you have to settle before or after handover? We haven't received our last invoice till today and our final inspection was 3 weeks ago![/quote]You're meant to settle with a cheque at handover but our bank went rogue and paid it via transfer two weeks prior. Re: Metricon Winchester 28- Keys! 1154Nov 14, 2018 5:30 pm Kimmykim I would be annoyed if my bank does that. I have to take note of that. Can you please outline an approx timeline and activity before final payment? https://r.tapatalk.com/shareLink?url=ht ... are_type=t Re: Metricon Winchester 28- Keys! 1155Nov 15, 2018 8:34 am excited_builders Kimmykim I would be annoyed if my bank does that. I have to take note of that. I would be very annoyed too. So did you send the invoice many days prior to final handover to be paid. I'm still not clear about that process. Can you please outline an approx timeline and activity before final payment? https://r.tapatalk.com/shareLink?url=ht ... are_type=t The invoice was passed to the broker with instructions that the bank cheque needed to be available at X branch by Y date, based on the original handover date of November 2. While we were overseas we got a text from the bank to say the transfer had been made. Absolutely nothing could be done at that point. Doesnt really matter, M were able to confirm payment received before handover and we wern't likely to hold things up on the day anyway. Saved me a trip to the bank. Re: Metricon Winchester 28- Keys! 1156Nov 15, 2018 10:42 am Booked some earth moving equipment for the weekend so that we can get our backyard under control. Plan this weekend is to scrape out the remaining rubble then run a rotary hoe over the lot. Get the garden beds in place for fruit frees as well. Then in two weeks we can get topsoil spread out and grass rolled out. Re: Metricon Winchester 28- Keys! 1157Nov 15, 2018 11:04 am blackcat20 Booked some earth moving equipment for the weekend so that we can get our backyard under control. Plan this weekend is to scrape out the remaining rubble then run a rotary hoe over the lot. Get the garden beds in place for fruit frees as well. Then in two weeks we can get topsoil spread out and grass rolled out. Our Bayside KDR Thread: viewtopic.php?f=31&t=78298 Re: Metricon Winchester 28- Keys! 1158Nov 15, 2018 11:06 am Drew01 blackcat20 Booked some earth moving equipment for the weekend so that we can get our backyard under control. Plan this weekend is to scrape out the remaining rubble then run a rotary hoe over the lot. Get the garden beds in place for fruit frees as well. Then in two weeks we can get topsoil spread out and grass rolled out. Re: Metricon Winchester 28- Keys! 1159Nov 15, 2018 11:58 am blackcat20 Drew01 blackcat20 Booked some earth moving equipment for the weekend so that we can get our backyard under control. Plan this weekend is to scrape out the remaining rubble then run a rotary hoe over the lot. Get the garden beds in place for fruit frees as well. Then in two weeks we can get topsoil spread out and grass rolled out. Our Bayside KDR Thread: viewtopic.php?f=31&t=78298 Re: Metricon Winchester 28- Keys! 1160Nov 16, 2018 5:49 am blackcat20 excited_builders Kimmykim I would be annoyed if my bank does that. I have to take note of that. I would be very annoyed too. So did you send the invoice many days prior to final handover to be paid. I'm still not clear about that process. Can you please outline an approx timeline and activity before final payment? https://r.tapatalk.com/shareLink?url=ht ... are_type=t The invoice was passed to the broker with instructions that the bank cheque needed to be available at X branch by Y date, based on the original handover date of November 2. While we were overseas we got a text from the bank to say the transfer had been made. Absolutely nothing could be done at that point. Doesnt really matter, M were able to confirm payment received before handover and we wern't likely to hold things up on the day anyway. Saved me a trip to the bank. https://r.tapatalk.com/shareLink?url=ht ... are_type=t Hmmm, I have checked your past posts and it seems that you are in NSW, not WA as I had thought. It pays to show your State in your avatar. Retaining wall regulations… 5 7906 Hi, you've probably already resolved this, however, Commbank will probably pay the funds to you after you send evidence the work is done regardless the change in the quotes. 1 35422 Ideally you would engage a landscaper to give you some insight what they may need in the space to make your vision come to life… 1 13713 |
