Browse Forums General Discussion Re: **help** is this damp or water damage 2Nov 13, 2018 6:56 am You can buy a moisture meter from Bunnings for $45 or a cheap one on ebay for $15 and you press it against the wall and it will tell you if theres a damp or water problem , the fact that its soft is a bad sign , if it was me l would call a plumber to check water leaks from shower causing it https://www.bunnings.com.au/crommelin-m ... r_p0911078 Re: **help** is this damp or water damage 4Nov 13, 2018 10:44 am Definitely arrange for a plumber to come out and have a look, a damp wall usually means there is a leak. there was an event. The question is whether the builder had the insurance and whether the event was covered. The workmanship is a separate conversation. 10 24028 Have look at your house plans and you will probably find that brick articulation joint has been missed. Maximum allowable spacing is 6M or 5.5M for a wall with window… 17 21006 Firstly the ableflex that has been installed needs (manufactures specification) a sealant cap over the top, preventing water draining down between the slab and the… 3 8110 |
