Browse Forums Building A New House 1 Nov 05, 2018 2:11 pm Hi Has anyone ever encountered the following problem: Concreter used a different set of plans to pour raft slab and when framer has gone to complete frame there has been some overhangs and also we have lost 120mm of slab as a result. Builder has said they are getting an amended approved plan? Does this sound right? This has caused a number of delays to our build as a result. Our house size is 36sq double storey Re: Slab poured incorrectly 2Nov 05, 2018 3:56 pm dhi7780 Hi Has anyone ever encountered the following problem: Concreter used a different set of plans to pour raft slab and when framer has gone to complete frame there has been some overhangs and also we have lost 120mm of slab as a result. Builder has said they are getting an amended approved plan? Does this sound right? This has caused a number of delays to our build as a result. Our house size is 36sq double storey Hello needing some advice. I was about to build my Alfresco and needed a new slab and remove exisiting slab as its not standard. So they start to excavate and jackhammer… 0 2666 Hi all, Trying to workout the minimum stepdown required between slab for my house and the outdoor alfresco area. Garage is 100mm lower than rest of the house and plan was… 0 3663 Thanks for the insights, that makes perfect sense, and yeah, I will be leaning on the experience of the excavator operator entirely. 6 11076 |
