Browse Forums Home Theatre & Automation Re: Can network/AV cables be installed after handover ? 2Mar 11, 2009 9:09 pm Kodiak Data Cabling onFaceBook Consult*, Design and Installation Data, TV, Home Theatre/ AV Cabling, Multi Room Audio, IP CCTV and Door Intercoms Ask for a Quote. *DIY DATA Cabling Is Ilegal Re: Can network/AV cables be installed after handover ? 11Mar 12, 2009 7:16 pm seroursliy go learn some building terms.....
the noggins are horizontal between the "studs" and can only be "rotated if the builders know what is going on they usualy put two nails in each end the holes drilled in the noggings are vertical holes.... conduits are usually attached to the studs with "saddles" and usualy only need to exit the top plate about 100- 200mm that is either flexi conduit or ridged stuff. sound liek you should just pay the extra money for it to be done while you have the gyrock off. only networking and phone lines has to be done bya technician, if you want do anyting else go ahead and do it just don't expect anyone to care if there a future issues with it. depending on your lay out pre con work is usualy about $1200- $1800 retro fit at least double that Kodiak Data Cabling onFaceBook Consult*, Design and Installation Data, TV, Home Theatre/ AV Cabling, Multi Room Audio, IP CCTV and Door Intercoms Ask for a Quote. *DIY DATA Cabling Is Ilegal yes it does, you've just not understood it. theres a difference. 4 5322 Depends what you're current inclusions are, but we're not including wardrobes and will just use second hand ones until we can save later on to get them built. Also have a… 3 11630 The unit normally clips into a metal plate screwed to the wall, either plate is not flush, or unit not hooked in and could be hanging from the pipes partly, either might… 2 15786 |
