Browse Forums Building A New House Re: Building a home with Langdon Builders Ballarat (Horsham) 163Oct 28, 2018 9:21 pm Handover was on Friday, went to do My first load in the dishwasher this afternoon and it started but after 5 min it stops and I get a F5 message. Which the instruction manual says is a water flow error. I contacted the SS and no response. ☹️ Re: Building a home with Langdon Builders Ballarat (Horsham) 164Oct 28, 2018 10:09 pm ![]() Handover was on Friday, went to do My first load in the dishwasher this afternoon and it started but after 5 min it stops and I get a F5 message. Which the instruction manual says is a water flow error. I contacted the SS and no response. ![]() Re: Building a home with Langdon Builders Ballarat (Horsham) 165Oct 28, 2018 10:27 pm ![]() ![]() Handover was on Friday, went to do My first load in the dishwasher this afternoon and it started but after 5 min it stops and I get a F5 message. Which the instruction manual says is a water flow error. I contacted the SS and no response. ![]() During handover the SS said it was all checked, he opened it and showed it was wet and said we have checked all the appliances. Obviously not a complete cycle 🤦🏼♀️ Re: Building a home with Langdon Builders Ballarat (Horsham) 166Oct 29, 2018 5:32 am ![]() ![]() ![]() Handover was on Friday, went to do My first load in the dishwasher this afternoon and it started but after 5 min it stops and I get a F5 message. Which the instruction manual says is a water flow error. I contacted the SS and no response. ![]() During handover the SS said it was all checked, he opened it and showed it was wet and said we have checked all the appliances. Obviously not a complete cycle 🤦🏼♀️ Re: Building a home with Langdon Builders Ballarat (Horsham) 167Oct 29, 2018 5:41 am ![]() Handover was on Friday, went to do My first load in the dishwasher this afternoon and it started but after 5 min it stops and I get a F5 message. Which the instruction manual says is a water flow error. I contacted the SS and no response. ☹️ It isn't something stupidly simple like the tap servicing the plumbing to the washer not being turned on sufficiently? Sorry, I know it is obvious but I remember my previous new home had the same issue - I just had to turn the little "thumb screw" tap (not sure what they are called) another half turn. Often these error messages are simply because the device isn't getting sufficient water pressure (or the amount of pressure it is programmed to "expect"). Re: Building a home with Langdon Builders Ballarat (Horsham) 168Oct 29, 2018 12:57 pm ![]() ![]() Handover was on Friday, went to do My first load in the dishwasher this afternoon and it started but after 5 min it stops and I get a F5 message. Which the instruction manual says is a water flow error. I contacted the SS and no response. ![]() It isn't something stupidly simple like the tap servicing the plumbing to the washer not being turned on sufficiently? Sorry, I know it is obvious but I remember my previous new home had the same issue - I just had to turn the little "thumb screw" tap (not sure what they are called) another half turn. Often these error messages are simply because the device isn't getting sufficient water pressure (or the amount of pressure it is programmed to "expect"). Re: Building a home with Langdon Builders Ballarat (Horsham) 169Oct 29, 2018 5:44 pm Starting to put everything into place, dishwasher was fixed today also 💁🏼♀️ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Building a home with Langdon Builders Ballarat (Horsham) 170Oct 29, 2018 5:57 pm ![]() ![]() Handover was on Friday, went to do My first load in the dishwasher this afternoon and it started but after 5 min it stops and I get a F5 message. Which the instruction manual says is a water flow error. I contacted the SS and no response. ☹️ It isn't something stupidly simple like the tap servicing the plumbing to the washer not being turned on sufficiently? Sorry, I know it is obvious but I remember my previous new home had the same issue - I just had to turn the little "thumb screw" tap (not sure what they are called) another half turn. Often these error messages are simply because the device isn't getting sufficient water pressure (or the amount of pressure it is programmed to "expect"). It was a kinked hose at the back of the dishwasher, very easy fix 😝 Re: Building a home with Langdon Builders Ballarat (Horsham) 171Oct 29, 2018 6:25 pm ![]() Starting to put everything into place, dishwasher was fixed today also ![]() Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Building a home with Langdon Builders Ballarat (Horsham) 172Oct 29, 2018 6:25 pm ![]() ![]() Starting to put everything into place, dishwasher was fixed today also ![]() Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Building a home with Langdon Builders Ballarat (Horsham) 173Oct 29, 2018 6:26 pm ![]() ![]() Starting to put everything into place, dishwasher was fixed today also ![]() Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Building a home with Langdon Builders Ballarat (Horsham) 174Oct 29, 2018 6:26 pm ![]() ![]() ![]() Starting to put everything into place, dishwasher was fixed today also ![]() Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Building a home with Langdon Builders Ballarat (Horsham) 175Oct 29, 2018 6:27 pm ![]() ![]() ![]() Starting to put everything into place, dishwasher was fixed today also ![]() Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Building a home with Langdon Builders Ballarat (Horsham) 176Oct 29, 2018 6:28 pm ![]() ![]() ![]() [quote="Trippypossum"]Starting to put everything into place, dishwasher was fixed today also ![]() Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ [/quote]Our door area looks awesome too love it Re: Building a home with Langdon Builders Ballarat (Horsham) 178Nov 02, 2018 1:21 am Poor puddles has been out of sorts, he’s slowly adjusting[/quote]My handover is the 8th had no tradies on site only a guy washing the dam windows had to have my fence pulled down they havent even concreted my drive or portico it's not finished ,I'm not a happy chappy Re: Building a home with Langdon Builders Ballarat (Horsham) 179Nov 02, 2018 1:22 am My handover is the 8th had no tradies on site only a guy washing the dam windows had to have my fence pulled down they havent even concreted my drive or portico it's not finished ,I'm not a happy chappy [/quote]It will take time for puddles to settle in same as ollie his a cutie Re: Building a home with Langdon Builders Ballarat (Horsham) 180Mar 06, 2019 6:57 pm Meeting with Langdons Maintanence team on Friday, hope everything is a easy fix. Hi, I don’t know if this is still relevant, but we’ve built in Geelong with Burbank and were quite happy with them. My son is building with Symmons (build starting in… 3 1393 Hi, I am planning to built my first home with Hudson Ridge. Their house is bit expensive - but their inclusions kind of attracts me. Does anybody wants to share their… 0 592 Dear All, Check all special conditions on McMaster Designer Homes before you engage with them. Ask for a standard contract before you hand any money over. The Special… 0 984 |
