Browse Forums Building A New House Re: Hickinbotham Torquay Mod - Post Handover 749Oct 06, 2018 10:30 pm they will send someone out to check the tiles but advised they get a lot of high moisture levels as a result of the pest company and havent found an issue yet - at least they woudl say that Have started process towards getting my pergola done now. rear of house was warm after handover back in march and can already feel the sun heating the glass and blinds on my rear glass doors. Re: Hickinbotham Torquay Mod - Post Handover 750Nov 06, 2018 4:02 pm Spent an afternoon at virginia nursury last weekend and made a few changes based on their advise I took out the yukka's before they got established and have put them back in pots Now just have Native Shrubs in the front yard - looking forward to what they will look like when grown Will be doing the same in the back once my pergola is done and am going to move all potted plants along the side of the house to give greenery outside the windows. Once pergola done and back plants ill update some more photos - hopefully within 4 weeks or so Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Hickinbotham Torquay Mod - Post Handover 751Nov 17, 2018 11:53 pm Entilzha Spent an afternoon at virginia nursury last weekend and made a few changes based on their advise I took out the yukka's before they got established and have put them back in pots Now just have Native Shrubs in the front yard - looking forward to what they will look like when grown Will be doing the same in the back once my pergola is done and am going to move all potted plants along the side of the house to give greenery outside the windows. Once pergola done and back plants ill update some more photos - hopefully within 4 weeks or so Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Hickinbotham Torquay Mod - Post Handover 752Dec 11, 2018 4:51 pm veranda approved by council today and delivery date is 7th JAN I wanted surfmist top and bottom but turns out my option was surfmist and plain grey or surfmist and woodland grey. so ended up with surfmist on the top and woodland grey underside - wanted to keep the roof same as the house roof plus i do feel that the surfmist roofing is better for keeping cool. All posts and beams will be surfmist so should contrast well with the woodland grey underside. and 2 opal skylights to probably be positioned above my 2 rear glass doors Photos in 4 weeks once its installed. Re: Hickinbotham Torquay Mod - Rear Verandah done 753Jan 15, 2019 8:12 pm Rear veranda finally done and that's pretty much done Still have a few things left inside - finally started fixing my skirting today and will be doing my touch-up painting just after Easter. Plants in front are going well though there are a couple that im not sure if i will have to replace as they just aren't growing I wont be planting anything in the back till after summer Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ It ended up being Surf mist Poles and Beams and Topside of roof (so matches house roofing) Underside of roof is Woodland Grey (was either that or monument) but it does match the fencing so looks good i think Skylights are are well placed and i don't have any real light issues in the rear of the house - but will wait till winter to make final judgement. Will be adding blinds in the 2 rear sections to at least come down 2-3 feet to block out the afternoon sun fully in summer as the late afternoon sun does heat up under the veranda a little bit, but the rear of the house is staying a bit cooler now that it doesn't get much direct sunlight like it used to. Hi, I'll be starting on my verandah repair soon - replace ledger, rafters, roofing iron, flashing etc. (fascia board already done). My question is about the timber ledger… 0 3344 1 3009 Hi All, see above image. The required setback from the rear boundary in my case is 5m, as you can see the shape of the site and location of the boundary is slightly… 0 8473 |
