Browse Forums Building A New House Re: Who's building with Clarendon?? 18502Sep 28, 2018 9:07 am Building Wentworth 33 CDC lodged to Council : 22 June 2018 Site excavation 31 July 2018 Slab 08 Aug 2018 Frame 22 Aug 2018 Roof 10 Sep 2018 Brick 24 Sep 2018 Re: Who's building with Clarendon?? 18507Sep 28, 2018 7:31 pm Building Wentworth 33 CDC lodged to Council : 22 June 2018 Site excavation 31 July 2018 Slab 08 Aug 2018 Frame 22 Aug 2018 Roof 10 Sep 2018 Brick 24 Sep 2018 Re: Who's building with Clarendon?? 18513Oct 02, 2018 12:22 pm SnowLeopard vannpaul SnowLeopard [quote="vannpaul"]report from our QA inspector - "Walls to shower area have not been completely waterproofed. Walls should be made waterproofed up to a height of 1800mm." Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Clarendon agreed that the quality could be improved and re-did the waterproofing as below. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ That's interesting. I'll raise it with the site manager and see. I noticed your walls and ceiling corners are sealed but our aren't. We were told it's because we got full height tiles. Did you get full height tiles? Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ yes Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ - full height tiles Thanks for the photos. Spoke with the site manager and he said don't have to do all the walls. It's been approved and certified.[/quote] If you are in NSW I believe that meets their standards. Queensland has to have all the walls in the shower done. Building a modified Madison 39 with Clarendon Homes in Tennyson homeone link: viewtopic.php?f=31&t=79106 Blog Link: https://minandb.wordpress.com/ Re: Who's building with Clarendon?? 18514Oct 02, 2018 4:50 pm we are building in NSW also. The difference that we wanted to stress to clarendon, that as an industry leader that promotes superior quality in their builds, that barely satisfying technical compliance is inadequate. as you probably noticed in some of the earlier shots, reaching the minimum heights in one small section of the wall and missing the rest altogether is not a 'fit for purpose' waterproofing treatment. once confronted about the level of quality, I do commend clarendon on accepting this argument and rectifying the works. Re: Who's building with Clarendon?? 18515Oct 02, 2018 5:23 pm vannpaul we are building in NSW also. The difference that we wanted to stress to clarendon, that as an industry leader that promotes superior quality in their builds, that barely satisfying technical compliance is inadequate. as you probably noticed in some of the earlier shots, reaching the minimum heights in one small section of the wall and missing the rest altogether is not a 'fit for purpose' waterproofing treatment. once confronted about the level of quality, I do commend clarendon on accepting this argument and rectifying the works. That's exactly right. Waterproofing is an integral part and must be ensured that it's superior quality rather than bare minimum. It's not they have to go out of their way to waterproof shower walls. Extra 20 bucks worth of membrane applied by a few brush strokes by someone who's already there, don't think it's so hard. We have emailed our customer service consultant. They sent us the waterproofing certificate but are also considering if it can be improved. Hopefully they will waterproof it. Killara 28 Re: Who's building with Clarendon?? 18516Oct 02, 2018 5:29 pm MinandB If you are in NSW I believe that meets their standards. Queensland has to have all the walls in the shower done. That's correct, it meets their minimum standards in NSW. Standards changed in 2010. Until then, all shower walls needed to waterproofed up to 1800mm. I wonder why would the standard change? Killara 28 Re: Who's building with Clarendon?? 18517Oct 02, 2018 6:06 pm my understanding is that the NCC 2016 only requires shower waterproofing on walls up to 150mm and that up to 1800mm needs to be Water resistant (rather than water proof). builders are using villaboard as a 'water resistant' surface in bathrooms, which whilst compliant, is not ideal. Re: Who's building with Clarendon?? 18518Oct 10, 2018 8:25 am Hi all, couple of trusses sagged and ceiling in a bedroom bulged from the right hand side wall to almost the middle of the house. Trusses have been fixed and gyprock re-done. Site manager confirmed it's all fixed. But looking at the roof tiles from outside, few tiles aren't straight and look wavy. Is it minor or should I be concerned? Please see attached photos and I'd appreciate sharing your opinion. Sagged ceiling before fix.Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Wavy roof tiles highlighted.Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Wavy roof tiles.Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Killara 28 Re: Who's building with Clarendon?? 18519Oct 11, 2018 2:13 pm Whenever i was concerned about something i tried to reach out to a supplier such as Boral to get an opinion...they might be able to advise if the uneven tiles will cause issues down the track... SnowLeopard Hi all, couple of trusses sagged and ceiling in a bedroom bulged from the right hand side wall to almost the middle of the house. Trusses have been fixed and gyprock re-done. Site manager confirmed it's all fixed. But looking at the roof tiles from outside, few tiles aren't straight and look wavy. Is it minor or should I be concerned? Please see attached photos and I'd appreciate sharing your opinion. Sagged ceiling before fix.Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Wavy roof tiles highlighted.Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Wavy roof tiles.Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ the stair balustrades? There is nothing special about these and I imagine literally every stair installer will be able to do this. 1 6717 The two 15mm holes are obviously not compliant. The Dept of Fair Trading would love to see this one! Do the gutters pool water after it stops raining? Although it's… 4 7844 |
