Browse Forums Building A New House Re: Building with Wisdom Homes 12609Sep 21, 2018 7:35 pm Bob the Bludger NickMutch Hi All - anyone have any experience with DA timings with Bayside Council? Hi Mickmuch, I did DA thru Bayside earlier this year. Lodged 16/01 approved 10/04. They are pretty slow compared to other councils. Bob Thanks Bob! Hopefully lodge by next weeks so it’s spproved by end of year.. Re: Building with Wisdom Homes 12611Sep 22, 2018 10:28 am Yes would get quotes but don’t book knockdown until CDC/DA approval. Whichever one applies. If you still have a mortgage over the existing property regardless of how small you will still need their sign off also. You should also apply for CDC demolition approval now also. The demo company can do that for you. Re: Building with Wisdom Homes 12612Sep 22, 2018 10:59 am Manhattan52 Yes would get quotes but don’t book knockdown until CDC/DA approval. Whichever one applies. If you still have a mortgage over the existing property regardless of how small you will still need their sign off also. You should also apply for CDC demolition approval now also. The demo company can do that for you. Thank you Manhattan52 But to get demo approval, don’t we need to sign with demo company first? Re: Building with Wisdom Homes 12613Sep 22, 2018 11:13 am One Manhattan52 Yes would get quotes but don’t book knockdown until CDC/DA approval. Whichever one applies. If you still have a mortgage over the existing property regardless of how small you will still need their sign off also. You should also apply for CDC demolition approval now also. The demo company can do that for you. Thank you Manhattan52 But to get demo approval, don’t we need to sign with demo company first? Yes you accept the demo quote but don’t proceed with the actual demolition until approval I meant previously don’t book demolition start date yet Re: Building with Wisdom Homes 12614Sep 22, 2018 11:43 am Manhattan52 One Manhattan52 Yes would get quotes but don’t book knockdown until CDC/DA approval. Whichever one applies. If you still have a mortgage over the existing property regardless of how small you will still need their sign off also. You should also apply for CDC demolition approval now also. The demo company can do that for you. Thank you Manhattan52 But to get demo approval, don’t we need to sign with demo company first? Yes you accept the demo quote but don’t proceed with the actual demolition until approval I meant previously don’t book demolition start date yet Thanks for the clarification 😊 Re: Building with Wisdom Homes 12615Sep 22, 2018 12:46 pm I tend to have random build anxieties whilst feeding my babies overnight:
1) how deep is your fridge space and how much does your fridge stick out? 2) for those with laundry joinery (underbench dryer and washer), where are your power points and water connection points? 3) power point in vanity yay or nay? Hubby has to recharge clippers and shaver and also occasionally uses clippers whist charging. What is more annoying? To have visible power point, use clippers with vanity door open, is it dangerous to charge the clippers in vanity? 4) I want to store and charge the stick vacuum in the broom cupboard in the laundry, where should I place the powerpoint? 5) where do you store the vacuum cleaner (we are having a cantilevered staircase so no storage) 6) Robot vacuum users, where does yours live? 7) For those with increased ceiling heights, did you need to alter the height of your shower screens? 8 ) Light switch locations, are standard locations ok or should I go through and make sure they aren't behind doors etc? Re: Building with Wisdom Homes 12616Sep 22, 2018 3:04 pm becks81 I tend to have random build anxieties whilst feeding my babies overnight: 1) how deep is your fridge space and how much does your fridge stick out? 2) for those with laundry joinery (underbench dryer and washer), where are your power points and water connection points? 3) power point in vanity yay or nay? Hubby has to recharge clippers and shaver and also occasionally uses clippers whist charging. What is more annoying? To have visible power point, use clippers with vanity door open, is it dangerous to charge the clippers in vanity? 4) I want to store and charge the stick vacuum in the broom cupboard in the laundry, where should I place the powerpoint? 5) where do you store the vacuum cleaner (we are having a cantilevered staircase so no storage) 6) Robot vacuum users, where does yours live? 1) Our space is 900mm deep, not sure how much fridge will stick out, but did give W the measurements of fridge to ensure it fits. 2) Power points for washer and dryer are underbench, not sure about position of the water connection, but since W have our model of our machines, a water connection point will be assumed... We also have a power point above the bench. 3) We have a power point in vanity on the side since it can't be too close to water source. 4) We thought of putting a power point in the WIL for vacuum but decided against it. 5) Plan to put one in the WIL. Hope that helps. Re: Building with Wisdom Homes 12617Sep 22, 2018 3:17 pm One becks81 I tend to have random build anxieties whilst feeding my babies overnight: 1) how deep is your fridge space and how much does your fridge stick out? 2) for those with laundry joinery (underbench dryer and washer), where are your power points and water connection points? 3) power point in vanity yay or nay? Hubby has to recharge clippers and shaver and also occasionally uses clippers whist charging. What is more annoying? To have visible power point, use clippers with vanity door open, is it dangerous to charge the clippers in vanity? 4) I want to store and charge the stick vacuum in the broom cupboard in the laundry, where should I place the powerpoint? 5) where do you store the vacuum cleaner (we are having a cantilevered staircase so no storage) 6) Robot vacuum users, where does yours live? 1) Our space is 900mm deep, not sure how much fridge will stick out, but did give W the measurements of fridge to ensure it fits. 2) Power points for washer and dryer are underbench, not sure about position of the water connection, but since W have our model of our machines, a water connection point will be assumed... We also have a power point above the bench. 3) We have a power point in vanity on the side since it can't be too close to water source. 4) We thought of putting a power point in the WIL for vacuum but decided against it. 5) Plan to put one in the WIL. Hope that helps. Thanks, One! My fear is that I shouldn't assume that WH will have thought about all the practicalities. I must admit, my kitchen, colours and electrical consultants have all notified me of issues where they feel something needs to be adjusted or omitted due to logistical issues. My kitchen consultant has been AMAZING. They are human, as am I, so I feel it is naive to expect that everything will function perfectly after the build. I know I'm overthinking a lot of things but I would hate to move in and think "I wish I had changed that when I had the chance" Re: Building with Wisdom Homes 12619Sep 22, 2018 8:48 pm becks81 I tend to have random build anxieties whilst feeding my babies overnight: 1) how deep is your fridge space and how much does your fridge stick out? 2) for those with laundry joinery (underbench dryer and washer), where are your power points and water connection points? 3) power point in vanity yay or nay? Hubby has to recharge clippers and shaver and also occasionally uses clippers whist charging. What is more annoying? To have visible power point, use clippers with vanity door open, is it dangerous to charge the clippers in vanity? 4) I want to store and charge the stick vacuum in the broom cupboard in the laundry, where should I place the powerpoint? 5) where do you store the vacuum cleaner (we are having a cantilevered staircase so no storage) 6) Robot vacuum users, where does yours live? 7) For those with increased ceiling heights, did you need to alter the height of your shower screens? 8 ) Light switch locations, are standard locations ok or should I go through and make sure they aren't behind doors etc? 1) my fridge sticks out 8cm so not too bad, it's 65cm deep 2) the power point should be in the cabinet so you could just drill a hole between the barrier 3) I've got power points in cabinets as I plan to do LED strip lighting under bench 4) if you want the stick vacuum in the cabinet then you'll need to put a power point there. 5) we don't have much storage for vacuum cleaner as we have floating staircase. We'll probably put it in the linen cupboard in our laundry 6) not planning on robot vacuum 7) we didn't alter shower screen height. They don't go to ceiling anyway so should be fine as is. I don't like light switches behind doors so I've avoided that too. Re: Building with Wisdom Homes 12620Sep 23, 2018 11:28 am In kitchen upgrades, I have seen some of you change the default free standing Cook top oven to separate cook top and oven wondering why is it so ? Is it better to have them separate instead of a single unit? Can someone please offer some advice? Im DESPERATE. Because I'm completely and utterly exhausted. How long are variations taking with other companies at the moment? We… 0 18465 In fairness nobody gave a crap about the ACCC and the gag clauses continued in the pro forma templates of a few other builders after the ACCC took on Wisdom, and more… 19 73443 Hi Everyone, I am exploring builder in NSW and received a very tempting quote from Wisdom home for their momentum series. I just want to know experience of building… 0 8233 |
