Browse Forums Building A New House Re: How to Identify Block Boundary 2Sep 14, 2018 11:15 am Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: How to Identify Block Boundary 5Sep 14, 2018 7:00 pm That will all depend on how well your builder laid out your slab, they could be off by as much as 100mm at times Re: How to Identify Block Boundary 6Sep 14, 2018 8:05 pm joannapaulp When you say the boundary peg was moved, do you mean the one that sticks up that you can see, or the one that is buried in the ground nearby (the actual boundary peg). The nail in the top of the buried one is the actual boundary point, maybe have a dog around and see if this is still there, should be within about 15-20cm of the visible one. Also, sometimes the estate marks up the block divisions on the kerb, might be a helpful starting point. This. The two-foot tall red and white stake is not the boundary peg, which is an official survey mark. Moving/tampering with survey marks is an offence (in QLD anyway). If the pegs are there, run a string line between them rather than trying to eyeball it. If one or more pegs are missing, the only way to reinstate is via a cadastral survey. 1 421 thanks Chippy, i hope they have applied sealer but i am doubt to be honest, so i am gonna do this job after handover. 8 16319 You should be able to encase the sewer but you will need it designed and approved and access to lot 580 to do the work 2 17194 |
