- James Hardie does not specify which tapes to use or supply certified tapes
- Only available in 2750mm width
- Reflective side facing outside - easily damaged by careless tradespeople
- Inconsistent Installation instructions - it doesn't help when the installer is unfamiliar with this product
- Do not use it with brick veneer - JM did not spell out if you can use it with brick veneer
- Not well-stocked - we ran out of material and had to wait for weeks for re-supply
- Poor sales and technical support
Should have stick with CSR/Bradford Enviroseal ProctorWrap!!!
