Browse Forums Building Standards; Getting It Right! Re: Insulation in new house 3Sep 04, 2018 10:07 pm alexp79 What is your construction system? Lightweight. Thx Re: Insulation in new house 4Sep 05, 2018 12:29 am Reflective insulation is highly important for lightweight construction. It not only provides a (minor though) thermal break for your studs but also creates a vapour permeable moisture barrier as your stud insulation should never be wet. The ideal construction from inside to outside: 1) battened cladding or brick veneer on ties; 2) air space (at least 25 mm but better 50 mm); 3) reflective insulation/moisture barrier; 4) OSB board; 5) studs filled with insulation batts; 6) plasterboard/gyprock; Good example here: https://www.kingspan.com/au/en-au/produ ... rmicav-xv# For Canberra it is certainly a must-to-have option. In addition, passive solar orientation (with good shading for summer) as well as additional thermal mass will be a significant plus as lightweight construction is not perfectly suitable for your climate zone no matter how insulated your house is. Re: Insulation in new house 5Sep 05, 2018 10:13 am alexp79 Reflective insulation is highly important for lightweight construction. It not only provides a (minor though) thermal break for your studs but also creates a vapour permeable moisture barrier as your stud insulation should never be wet. The ideal construction from inside to outside: 1) battened cladding or brick veneer on ties; 2) air space (at least 25 mm but better 50 mm); 3) reflective insulation/moisture barrier; 4) OSB board; 5) studs filled with insulation batts; 6) plasterboard/gyprock; Good example here: https://www.kingspan.com/au/en-au/produ ... rmicav-xv# For Canberra it is certainly a must-to-have option. In addition, passive solar orientation (with good shading for summer) as well as additional thermal mass will be a significant plus as lightweight construction is not perfectly suitable for your climate zone no matter how insulated your house is. Thx for your help. I am saying that double brick has similar thermal performance due to thermal mass effect. It will be still very interesting to see the state of your framing after 10-15… 10 23106 Hey guys building a new place through a volume builder and just wondering if i should complain to the site supervisor as we just had plasterboard installed. Looks like… 0 8910 |
