Browse Forums Kitchen Corner Re: Has anyone removed laminate flooring skirting. 3Aug 29, 2018 11:08 am Just rip it out, you wont see it behind the fridge Cutting Edge Kitchens and Cabinet Making http://cuttingedgekitchens.net.au http://www.facebook.com/pages/Cutting-Edge-Kitchens/290484196676 Mobile : 0419 430 575 PH: 9452 4772 Fax :9452 4772 cuttingedgekitchens@outlook.com Re: Has anyone removed laminate flooring skirting. 4Aug 29, 2018 11:44 am CuttingEdgeKitchens Just rip it out, you wont see it behind the fridge Do you know if its hard to get off? Assuming it's glued down. Re: Has anyone removed laminate flooring skirting. 5Aug 29, 2018 12:47 pm goldencrumble CuttingEdgeKitchens Just rip it out, you wont see it behind the fridge Do you know if its hard to get off? Assuming it's glued down. No glue, just a few little nails. Get a chisel under it and lever it up. Very easy Cutting Edge Kitchens and Cabinet Making http://cuttingedgekitchens.net.au http://www.facebook.com/pages/Cutting-Edge-Kitchens/290484196676 Mobile : 0419 430 575 PH: 9452 4772 Fax :9452 4772 cuttingedgekitchens@outlook.com Re: Has anyone removed laminate flooring skirting. 6Aug 29, 2018 5:40 pm goldencrumble CuttingEdgeKitchens Just rip it out, you wont see it behind the fridge Do you know if its hard to get off? Assuming it's glued down. Definitely won't be glued, as CEK said, chisel under and pull. Keep off cut. Can come in handy if you need to fill in any spots particularly if fridge doesn't cover the whole wall. Building Standards; Getting It Right! Is this acceptable in a new house build. Floors where installed by builder. Already chips in board and skirting is not flush 0 186 Just about completed a renovation project and hit a small issue that we didn’t see We have laminate floors now where we had tiles before (turned out it was actually 2… 0 4931 |
