Browse Forums Building A New House Re: Building first home - adelaide 5Aug 28, 2018 11:17 am Hi there, 1. Turn-key packages are supposed to mean a property that someone can purchase and immediately use. Having said that, there are a lot of builders who advertise turn-key that is not truly turn-key. Most of the time there will be things you will need to do. The home I am currently building is about 90% turn-key. The home will be built and I could move in after it is complete but there are several things missing that I will need to do myself because the builder simply doesn't do it (or will charge an arm and a leg for). Here are a few things to consider:
2. Soil removal is usually quoted on the contract as an allowance. Our allowance as $1,000 and when we went to the final builders interview it was revised to $4,000. Most builders will get a skip bin placed on site for rubbish removal. 3. Yes there could be hidden extras. The Sales Consultant will provide you with a quote make sure you check it properly. If the quote indicates an allowance for tiling for the whole house at an unrealistic price then this will be revised later on. Make sure you check the quote, for example evaporative cooling is not the same a ducted air-conditioning system. Some builders offer you evaproative cooling and it kind of looks like ducted air conditioning but it isn't (and would be an upgrade to go to ducted air. So it looks like we finally have some movement on site! Definitely later than expected, but I'll take any progress at this point. I'll drop by over the weekend to get… 5 28305 Building a new home, and looking for a garage builder (home builder not contracted to do this). Someone to build steel garage (double), colorbond, including supply and… 0 3284 Can anyone give me any onfo on New Homes WA? Good or bad, hopefully good just need to know if my choice was good or not? Thanks ❤️ 0 8989 |
