The island is 2632 and the under window bench is around 3310.
Browse Forums Building A New House Re: Metricon Winchester 28- Home Straight 848Aug 17, 2018 10:32 pm Our Bayside KDR Thread: viewtopic.php?f=31&t=78298 Re: Metricon Winchester 28- Home Straight 851Aug 18, 2018 7:56 pm blackcat20 MyFirst I thought expose down pipe where water just run down the brick wall and then to the slab Isn't that a big no no? Definitely a big no no. Once the bricks have been cleaned they'll attach th remainder of the down pipe and connect it. They should have temporary plastic down pipe to direct water away during construction stage. Re: Metricon Winchester 28- Home Straight 852Aug 18, 2018 8:00 pm MyFirst blackcat20 MyFirst I thought expose down pipe where water just run down the brick wall and then to the slab Isn't that a big no no? Definitely a big no no. Once the bricks have been cleaned they'll attach th remainder of the down pipe and connect it. They should have temporary plastic down pipe to direct water away during construction stage. Re: Metricon Winchester 28- Home Straight 853Aug 20, 2018 9:02 am Re: Metricon Winchester 28- Home Straight 855Aug 20, 2018 9:21 am I found getting a response from fencing contractors like playing Russian Roulette... I rang 11, and 2 got back to me... End up with the third quote from a guy who travels down from South Seymour via word of mouth, and he was the cheapest quote... Go figure Our Bayside KDR Thread: viewtopic.php?f=31&t=78298 Re: Metricon Winchester 28- Home Straight 856Aug 20, 2018 9:27 am I went with Endless fencing. The price was very reasonable for two side fences and a merbau gate. Their work looks good too. Re: Metricon Winchester 28- Home Straight 857Aug 20, 2018 10:04 am Drew01 I found getting a response from fencing contractors like playing Russian Roulette... I rang 11, and 2 got back to me... End up with the third quote from a guy who travels down from South Seymour via word of mouth, and he was the cheapest quote... Go figure I have that problem at well. Rang many but only 2 called back. 😓 Re: Metricon Winchester 28- Home Straight 859Aug 20, 2018 10:07 am Looks promising! So near to finishing line! Do you have any idea how long will be from PCI to handover? Re: Metricon Winchester 28- Home Straight 860Aug 20, 2018 10:14 am Kimmykim Looks promising! So near to finishing line! Do you have any idea how long will be from PCI to handover? Hmmm, I have checked your past posts and it seems that you are in NSW, not WA as I had thought. It pays to show your State in your avatar. Retaining wall regulations… 5 8038 Hi, you've probably already resolved this, however, Commbank will probably pay the funds to you after you send evidence the work is done regardless the change in the quotes. 1 35706 Ideally you would engage a landscaper to give you some insight what they may need in the space to make your vision come to life… 1 13945 |
