Browse Forums Heating, Cooling & Insulation Re: Please help. Need advice 11Aug 14, 2018 10:58 pm Bels The modulating damper feature will save you something compared to the traditional zone controller with on/off control of the air to zones. It's just if you can see the value in the return on investment and how long it will take to payback. Yeah very true. Thank you so much for your input, it’s really helped. I just wanted to hear all this from a neutral and not just the sale pitch from supplier. What I might do now is exactly that. I’m going to ask them to provide these specs if they can and make a call on it then, also taking into consideration the advice from here as well. Thanks again Metricon Franklin 53 modified Thank you @. Tried to play with the facade models but the exact colour is not matching up. 2 3310 Levelling compound Ardit is the best but buy a bag of sand and make sand dam to protect your wood floor 2 15282 XCEM Alpha flooring seems to relatively new and I could not found any reviews. Have you or someone you know have used it and would recommend over other subfloor options?… 2 7612 |
