Browse Forums Building A New House Re: Building on Slope -right to left 1.25m- land - suggestio 5Aug 14, 2018 9:12 pm benblinkau You built on a slope, so whether you retain or do a split level, you will be forking out some extra cash. You can’t make the slope disappear, so you have to deal with it one way or another which = $$$ Decided to retain, but not sure which of the below retain option is best? a) If we cut on right side, and build retaining of 1.3m right, then whole house level is getting almost below road level, and lower than my high side neighbour. b) If we cut and fill, then I may have to build retaining walls both sides which cost me too much c) If I build retaining wall of 1.3m on low side and do only Fill, then my house will be higher as well as can get flat back and front yards. By the way, do I need to do drop edge beam in this scenario? Building on Slope -right to left 1.25m- land - suggestions n 6Aug 15, 2018 10:43 pm If not open to consider split level I’d go the fill option. Higher house, More sunlight to yard and house in windows Less likely to be impacted on cut high side by shadowing by neighbors house But seek architects advice. They are the professionals and will take them not account neighboring houses, street level etc Re: Building on Slope -right to left 1.25m- land - suggestio 7Aug 16, 2018 7:55 am Gaudi If not open to consider split level I’d go the fill option. Higher house, More sunlight to yard and house in windows Less likely to be impacted on cut high side by shadowing by neighbors house But seek architects advice. They are the professionals and will take them not account neighboring houses, street level etc Thanks Gaudi, appreciate your suggestions, going with this option Re: Building on Slope -right to left 1.25m- land - suggestio 8Aug 16, 2018 8:07 am ratna I wouldn't proceed too far beyond the architects Sketch Without preliminary engineering Data and Construction costs Slab & Formwork Costs Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Need advice on the backyard plan above. Should I excavate and cut all of the dirt to level with the house slab or semi-excavate as per photo above? Both left and right… 0 18865 Hi All, We have recently purchased a sloping block (3.5m fall building envelope, 6m overall). Just wondering if you know of any good builders that you would recommend for… 0 879 you need a fridgie to answer but I would think you vac the whole system then add gas if you have a leak, unless it is new install with the gas already loaded, in that case… 1 2320 |
