Browse Forums Building A New House Re: KDR RAWSON Benham 33 in hills area of Sydney 3Apr 06, 2018 5:15 pm Build thread [size=200]KDR RAWSON Benham 33 in hills area of Sydney[/size] Re: KDR RAWSON Benham 33 in hills area of Sydney 5Apr 06, 2018 5:24 pm Build thread [size=200]KDR RAWSON Benham 33 in hills area of Sydney[/size] Re: KDR RAWSON Benham 33 in hills area of Sydney 6Apr 16, 2018 10:26 am Build thread [size=200]KDR RAWSON Benham 33 in hills area of Sydney[/size] Re: KDR RAWSON Benham 33 in hills area of Sydney 7Apr 16, 2018 10:27 am Build thread [size=200]KDR RAWSON Benham 33 in hills area of Sydney[/size] Re: KDR RAWSON Benham 33 in hills area of Sydney 8Apr 16, 2018 10:31 am Build thread [size=200]KDR RAWSON Benham 33 in hills area of Sydney[/size] Re: KDR RAWSON Benham 33 in hills area of Sydney 9Apr 16, 2018 12:13 pm Build thread [size=200]KDR RAWSON Benham 33 in hills area of Sydney[/size] Re: KDR RAWSON Benham 33 in hills area of Sydney 10Apr 16, 2018 4:59 pm Build thread [size=200]KDR RAWSON Benham 33 in hills area of Sydney[/size] Re: KDR RAWSON Benham 33 in hills area of Sydney 12Apr 20, 2018 10:37 am Build thread [size=200]KDR RAWSON Benham 33 in hills area of Sydney[/size] Re: KDR RAWSON Benham 33 in hills area of Sydney 13Aug 12, 2018 12:30 pm Build thread [size=200]KDR RAWSON Benham 33 in hills area of Sydney[/size] Re: KDR RAWSON Benham 33 in hills area of Sydney 14Aug 12, 2018 12:31 pm Build thread [size=200]KDR RAWSON Benham 33 in hills area of Sydney[/size] Re: KDR RAWSON Benham 33 in hills area of Sydney 15Oct 26, 2018 8:19 am Hi AIB, looks like all is going much better now you're in the construction phase. Do you mind me asking who was your PCA & Plan Presenter? Also who are you using for your inspections during the build process they seem very thorough and we'll be needing the same for our build in the Hills hopefully starting before the end of the year. Build Thread: Building a Rawson Chifley 42 in Baulkham Hills NSW All progress photos on Google Photos: HERE Re: KDR RAWSON Benham 33 in hills area of Sydney 16Oct 31, 2018 7:46 pm JiMb00 Hi AIB, looks like all is going much better now you're in the construction phase. Do you mind me asking who was your PCA & Plan Presenter? Also who are you using for your inspections during the build process they seem very thorough and we'll be needing the same for our build in the Hills hopefully starting before the end of the year. Hi Jimb00 I have messaged you what you were asking for. Good luck with your construction. Cheers. Build thread [size=200]KDR RAWSON Benham 33 in hills area of Sydney[/size] Re: KDR RAWSON Benham 33 in hills area of Sydney 17Nov 05, 2018 8:42 pm Build thread [size=200]KDR RAWSON Benham 33 in hills area of Sydney[/size] Re: KDR RAWSON Benham 33 in hills area of Sydney 18Nov 05, 2018 8:42 pm Build thread [size=200]KDR RAWSON Benham 33 in hills area of Sydney[/size] Re: KDR RAWSON Benham 33 in hills area of Sydney 19Nov 06, 2018 7:22 am AIB Just wondering how the soft white foam support things on top of it though concrete poured between foam blocks and on the steel waffle pod. A bit worry to me though several of my friends told me the same done on their site when they built their house. Is it something industry standard to use foam under concrete nowadays? ! I came into this thread because we very nearly built a Benham 33 … … but I see nobody's answered this? The answer is that the foam isn't intended to support any weight at all. It's got two functions; it holds the concrete into it's "waffle" shape while the concrete sets, and it also acts as insulation underneath (although I don't quite understand the insulation part to be honest - I thought the soil was very good insulation by itself). Once the concrete has set, if you could get to it you could pretty-much take the foam away. And yeah, it's extremely common, most houses in Sydney are built this way. I think there are certain soil conditions where they don't; but with most Sydney soil conditions & locations, if the house is being built on a slab which is sitting on the ground then they're probably building it with these waffle pods. Re: KDR RAWSON Benham 33 in hills area of Sydney 20Nov 06, 2018 3:34 pm Forg AIB Just wondering how the soft white foam support things on top of it though concrete poured between foam blocks and on the steel waffle pod. A bit worry to me though several of my friends told me the same done on their site when they built their house. Is it something industry standard to use foam under concrete nowadays? ! I came into this thread because we very nearly built a Benham 33 … … but I see nobody's answered this? The answer is that the foam isn't intended to support any weight at all. It's got two functions; it holds the concrete into it's "waffle" shape while the concrete sets, and it also acts as insulation underneath (although I don't quite understand the insulation part to be honest - I thought the soil was very good insulation by itself). Once the concrete has set, if you could get to it you could pretty-much take the foam away. And yeah, it's extremely common, most houses in Sydney are built this way. I think there are certain soil conditions where they don't; but with most Sydney soil conditions & locations, if the house is being built on a slab which is sitting on the ground then they're probably building it with these waffle pods. Thank you Build thread [size=200]KDR RAWSON Benham 33 in hills area of Sydney[/size] Even if it's not being sub-divided and you want to keep it as Torrens title, you will still need to talk to a town planner or Council themselves, to see if they will allow… 1 11156 Thanks again Simeon for being so elaborate. Appreciate it. Its gives us a very idea. Kind Regards 4 3813 CDC Housing Code 3 When to apply Floor Area external face of wall vs Gross Floor Area internal face of wall. Reading thru CDC Housing Code 3, lets take a lot 915sqm.… 0 16742 |
