Browse Forums General Discussion Re: Hairline Cracks and Sound from walls 3Aug 11, 2018 4:20 am Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Hairline Cracks and Sound from walls 4Aug 11, 2018 11:50 am Mr. Sausage My understanding is that such things - to a greater or lessor extent - can and do occur in houses made using metal frames. Mine is a wooden frame which is why I am concerned more.The metal sound is coming from stud and other is the wooden sound. Thanks Re: Hairline Cracks and Sound from walls 6Aug 12, 2018 4:41 am Dataone111 Thanks for the the info Do you have the Engineering & Construction documentation? Specifically, Wind loading classification and engineering onsite frame fixing requirements? Was you house properly inspected, ie compliance,engineering & Photos taken at the framing stage? if You don't have E docs, Please get copies from your council & post back Also Read this Slab heave is alive & Well Watch out & check combination effects, Heave, shifting winds on roof loads-> joint/connections, photos required Cheers Chris Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Hairline Cracks and Sound from walls 7Aug 12, 2018 12:39 pm Thank you , I will get those documents from council to post back. Meanwhile I have watered the house for around 2 hours today morning and I am not hearing any sound since then but I will observe it .Thanks for your help Prady Re: Hairline Cracks and Sound from walls 8Aug 13, 2018 8:27 am Dataone111 you are welcome , also reach out to mauromario and others, post back & goodluck Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Hairline Cracks and Sound from walls 9Aug 13, 2018 12:59 pm Hi to everyone who is having trouble with your house, please take as many photos as you even if your site manager tells you cannot go on site its crap it is there way of hiding the problem they build into new homes. I went any time I wanted when the site manager would question me I'd say its my land and I can enter any time I want even after they tell me health and safety I'd say ill be carefully. Look the reason iam saying this I took photos from empty block of land to finished build and right through to last week I have over 3000 photos, I researched everything and with the help of Geo1 and StructuralBIMGuy with the information they gave me it was an eye opener i took that information and all the photos I had the builder had no answer so vcat went in our favor. The member of vcat said he had never seen so many photos and detail in our folders the builder had only 2 reports that really did nothing for their case. So the member told the builder you have no chance deal with it now. To everyone who is in the middle of building take as many photos as you can before and afterwards it will help your case in the long run. Good luck to everyone. Re: Hairline Cracks and Sound from walls 10Aug 13, 2018 2:33 pm Hi, Thanks for your help. I brought this house from its first owner, so i didn't have any photos during the construction. I have done building inspection when i brought this property but not a structural inspection. I have waterered the house yesterday and the noice is reduced a lot. I am planning to bring a structurl engineer or buildfix.com to check on this. Meanwhile the builder is saying that any crack upto 1mm in Year 1 and 2 mm in Year 2 is under the allowed limit. I think it's going to be more than 2 mm soon in that case they will be forced to do the repair but my problem is it safe to wait or not I am confused in this matter and i live in Sydney. Thanks .. Re: Hairline Cracks and Sound from walls 11Aug 13, 2018 2:44 pm Hi. Dataone111 Never belive what the builder tells you as I have learned over the years fighting the builder everything they tell you within standards, get your own civil and structual engineer they will tell you if you needed drainage system put in place during the build and after hand over you have 10 years warranty by law in Australia, I've just finished at Vcat I have learned so much in 3.5 years. Have your floor levels checked and see if you have slab movement arm yourself with information from people on this forum, just wondering are you in Victoria if yes I can give you names of great engineers that are not scared to take on builders. Keep me posted. Regards Re: Hairline Cracks and Sound from walls 12Aug 13, 2018 8:21 pm If you can hear cracking in your house then it can be thermal shock and or more likely foundation movement. Check your cornices for cracks and your doors for even margins, especially double doors can tell a tale. Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog Re: Hairline Cracks and Sound from walls 13Aug 13, 2018 9:43 pm I hear Cornell engineering I think they are in Sydney they are well known give them a call they will guide you through this they are good at what the do. Kind Regards. Re: Hairline Cracks and Sound from walls 14Aug 14, 2018 8:04 am Thanks for the advice, I think it’s the thermal shock as the notice wasn’t there for 2 days since I watered the house and came back after that Thanks Re: Hairline Cracks and Sound from walls 15Aug 14, 2018 8:05 am Mauromario I hear Cornell engineering I think they are in Sydney they are well known give them a call they will guide you through this they are good at what the do. Kind Regards. I will call them today Thanks Re: Hairline Cracks and Sound from walls 16Aug 14, 2018 8:06 am building-expert If you can hear cracking in your house then it can be thermal shock and or more likely foundation movement. Check your cornices for cracks and your doors for even margins, especially double doors can tell a tale. I think it’s thermal shock Re: Hairline Cracks and Sound from walls 17Aug 14, 2018 9:13 am Mauromario Hi. Dataone111 Never belive what the builder tells you as I have learned over the years fighting the builder everything they tell you within standards, get your own civil and structual engineer they will tell you if you needed drainage system put in place during the build and after hand over you have 10 years warranty by law in Australia, I've just finished at Vcat I have learned so much in 3.5 years. Have your floor levels checked and see if you have slab movement arm yourself with information from people on this forum, just wondering are you in Victoria if yes I can give you names of great engineers that are not scared to take on builders. Keep me posted. Regards I am in Sydney and wondering which ones will be good for it I am doing some research on google now Thanks Re: Hairline Cracks and Sound from walls 18Aug 14, 2018 10:17 am In my experience thermal expansion is uncommon to cause noise in ordinary timber framed BV dwelling with roof tiles Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog Re: Hairline Cracks and Sound from walls 19Aug 14, 2018 10:34 am I think it’s time to bring in structural engineer and I have talked to couple of structural engineers but most are vary to take on to builder if that happens if they don’t agree to the issue I am yet to find a good one here in Sydney yet. Thanks Re: Hairline Cracks and Sound from walls 20Aug 14, 2018 10:39 am 1 before you take on your builder you need a correct diagnosis Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog The spacing of the studs looks pretty large especially for a load bearing wall. 3 11281 It sounds like you have a crack in your garage where the wall meets the ceiling, along the shadow line on the… 0 17301 Do you have a scope of works? If have texture on wall now, the patch will show through The standard for repair of texture is to patch, re-texture corner to corner,… 5 7029 |
