Browse Forums Building Standards; Getting It Right! 1 Aug 06, 2018 1:12 pm follow my build Arden homes Votivo 37 iin south east: https://forum.homeone.com.au/viewtopic.php?f=31&t=88622 Re: Surveyors role 3Aug 08, 2018 6:07 am Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Surveyors role 4Aug 08, 2018 7:09 am follow my build Arden homes Votivo 37 iin south east: https://forum.homeone.com.au/viewtopic.php?f=31&t=88622 Re: Surveyors role 7Aug 08, 2018 8:22 pm Gaudi pEast I can easily get as much concrete out I think by my bare hands looking at it Good you have pictures. ______________________________ “Note: Legislation introduced on 1 September 2016 prevents the builder from appointing the private building surveyor. The appointment of the private building surveyor must be made by the owner or an agent of the owner other than the builder. “ _____________________________ My questions/suggestions to you: Have you called the VBA for advice? On occasion they do provide helpful advice. Has your builder replied in writing? If not, have you spoken with the building company director/registered builder listed on your contract, construction manager or someone senior? Or Have you or your building consultant sent a letter/email to the building surveyor and copied the builder in listing the most significant concerns that do not meet engineering plans, code and the standards etc requesting a response? You may be aware that the RBS usually sends out an inspector to site for the inspections, so may not know your site well or at all. ______________________ My RBS did not act on my emails even though they assured me they would. Only when my building consultant put the key issues in an email to RBS, engineer and builder did RBS put a building notice on the builder. Are you building with a builder who only builds with Hebel? My private inspector wrote to the Surveyor and they send 2 persons to investigate but when I asked for report the they refused saying they don’t have anything g new. Despite the fact the builder has given to me in writing that on their visit they cut plaster and hebel to fix the things. My current concern is regarding the slab under main door - hebel was put in March but they left this as is - then again in July they put hebel back again at other places but left this as is. Now with PCI only a few days away they will put underneath it and then blame me I think on one pretext or the other. follow my build Arden homes Votivo 37 iin south east: https://forum.homeone.com.au/viewtopic.php?f=31&t=88622 Re: Surveyors role 8Aug 09, 2018 6:51 am pEast Thanks for the photos, but unfortunately it is after the event..if you get my gist Do You have detailed photos of the Reinforcement Placement and inspection Slab report, did they check concrete Slump and Take a cone sample,etc,etc? More info Required Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Surveyors role 9Aug 09, 2018 9:07 am StructuralBIMGuy @pEast Thanks for the photos, but unfortunately it is after the event..if you get my gist Do You have detailed photos of the Reinforcement Placement and inspection Slab report, did they check concrete Slump and Take a cone sample,etc,etc? More info Required StructuralBIMGuy - thanks for feedback - this slab is still as it is - still to have hebel put in - just a few days before PCI - I think my private inspector too hasn’t had a proper look at it follow my build Arden homes Votivo 37 iin south east: https://forum.homeone.com.au/viewtopic.php?f=31&t=88622 Re: Surveyors role 10Aug 10, 2018 7:28 am pEast StructuralBIMGuy @pEast Thanks for the photos, but unfortunately it is after the event..if you get my gist Do You have detailed photos of the Reinforcement Placement and inspection Slab report, did they check concrete Slump and Take a cone sample,etc,etc? More info Required I think my private inspector too hasn’t had a proper look at it Yep, That's what I'm seeing from your photos poor concrete mix & placement , Inadequate Reinforcement cover, etc. The following trades also see that & It's not a simple fix, best avoided by proper supervision Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Surveyors role 11Aug 15, 2018 10:05 pm pEast Now with PCI only a few days away they will put underneath it and then blame me I think on one pretext or the other. Blame you!! Remind them you are not the builder. You don’t seem satisfied with the responses you’ve had. Call the VBA or have your inspector call the surveyor and the builder to get a response for you. If the surveyor is happy the work meets code, they can say so in writing. Re: Surveyors role 12Sep 05, 2018 6:01 pm StructuralBIMGuy @pEast Thanks for the photos, but unfortunately it is after the event..if you get my gist Do You have detailed photos of the Reinforcement Placement and inspection Slab report, did they check concrete Slump and Take a cone sample,etc,etc? More info Required Thanks StructuralBIMGuy - I used your wording of poor concrete mix and the builder then got the engineering for the slab under main door But I don’t think they have followed it correctly because the ends at both sides has hebel put in therefore leaving cavity on the sides. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ follow my build Arden homes Votivo 37 iin south east: https://forum.homeone.com.au/viewtopic.php?f=31&t=88622 Re: Surveyors role 13Sep 11, 2018 10:14 am pEast What happens if Surveyor’s Recommendations r not followed by builder and continues the build. The Surveyor then just issues the certificate without checking in Melbourne Re: Surveyors role 14Sep 11, 2018 10:35 am sweetswisssteel pEast What happens if Surveyor’s Recommendations r not followed by builder and continues the build. The Surveyor then just issues the certificate without checking in Melbourne I too did independent building inspector but they missed it. follow my build Arden homes Votivo 37 iin south east: https://forum.homeone.com.au/viewtopic.php?f=31&t=88622 Re: Surveyors role 16Sep 11, 2018 10:55 am sweetswisssteel Darbecca, happily recommend My inspector was Kevin from NHI. Darbecca is the company and the inspection varies from empoyee to employee. Similarly, the Surveyor also sends out inspectors and it comes down to how the inspector is. You can get a bad inspection from either of them. In case of private inspector the best scenario is he does it himself like Sam, Kevin etc - then the chances of money’s wirth r more follow my build Arden homes Votivo 37 iin south east: https://forum.homeone.com.au/viewtopic.php?f=31&t=88622 Re: Surveyors role 17Sep 11, 2018 8:36 pm If you got the right consultant you wouldn't be asking questions here on the forum. Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog Re: Surveyors role 19Sep 12, 2018 8:25 am pEast StructuralBIMGuy @pEast Thanks for the photos, but unfortunately it is after the event..if you get my gist Do You have detailed photos of the Reinforcement Placement and inspection Slab report, did they check concrete Slump and Take a cone sample,etc,etc? More info Required Thanks StructuralBIMGuy - I used your wording of poor concrete mix and the builder then got the engineering for the slab under main door But I don’t think they have followed it correctly because the ends at both sides has hebel put in therefore leaving cavity on the sides. No they didn't follow the engineering details correctly Generally I would recommend ask for an extended warranty for such defects But now at least you are covered should you have problems in the future Cheers Chris Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Surveyors role 20Sep 12, 2018 8:35 am StructuralBIMGuy pEast StructuralBIMGuy @pEast Thanks for the photos, but unfortunately it is after the event..if you get my gist Do You have detailed photos of the Reinforcement Placement and inspection Slab report, did they check concrete Slump and Take a cone sample,etc,etc? More info Required Thanks StructuralBIMGuy - I used your wording of poor concrete mix and the builder then got the engineering for the slab under main door But I don’t think they have followed it correctly because the ends at both sides has hebel put in therefore leaving cavity on the sides. No they didn't follow the engineering details correctly Generally I would recommend ask for an extended warranty for such defects But now at least you are covered should you have problems in the future Cheers Chris Thanks StructuralBIMGuy - your feedback is very much appreciated regarding this. Will post once my I show it to my inspector on PCI day. follow my build Arden homes Votivo 37 iin south east: https://forum.homeone.com.au/viewtopic.php?f=31&t=88622 |
