Browse Forums Building A New House Re: Building at Bardia - New Breeze 871Aug 07, 2018 1:20 pm regmiboyer Hi Guys, [URGENT HELP REQUIRED] I have a query and need a second opinion. Mine is a small lot(8m width). My builder took more than 3 months to finalise the design, complete structure design, Bushfire and Sydnbey water approvals. He was ready to submit for CDC approval and the certifier reverted back saying that we cannot build second storey up to the fence. Let me explain my plan. I have left 1.3 m easement space on one end and occuping upto the fence on the other side. Now the builder says that the certifier denied to accept the plan stating that the first storey should have an easement of 1.3 meters on either sides. This is causing a narrow width on the first floor and taken away all the charm. CDC seems right to me, but I do understand uour dilemmas, unfortunately, if you didnt agree with CDC, you need to go through DA hoping DA will approve it. Otherwise, its a waste of time. Either way, your neighbor will need to approve it as well. If your neighbor reject it because of your first floor too close to theirs, they can reject it and you wont be able to build. Building Wentworth 33 CDC lodged to Council : 22 June 2018 Site excavation 31 July 2018 Slab 08 Aug 2018 Frame 22 Aug 2018 Roof 10 Sep 2018 Brick 24 Sep 2018 Re: Building at Bardia - New Breeze 872Aug 07, 2018 1:26 pm Thanks for replying wentworth33, Is there a document that has more information about the easement. I am refering to the one attached and I read it on ppage 53, Under side setbacks bullet number 9 speaks about our kind of lot which says "In Small Lot Housing Areas, the zero setback may extend over 2 storeys. There is no limit on the length of single storey wall built to a zero lot boundary. However dwelling bulk must take into account impact on solar access to neighbouring properties (Section 1.6) and setbacks (Figure 30)." https://www.campbelltown.nsw.gov.au/files/assets/public/document-resources/builddevelop/planning-policies-and-controls/edmondsonparksouthdevelopmentcontrolplan2012.pdf Re: Building at Bardia - New Breeze 875Aug 07, 2018 3:14 pm Tolgz Is anyone waiting on DA through Campbelltown council? Just curious at how long it takes or has taken? i heard it takes around 6 months? Re: Building at Bardia - New Breeze 876Aug 07, 2018 3:15 pm regmiboyer Thanks for replying wentworth33, Is there a document that has more information about the easement. I am refering to the one attached and I read it on ppage 53, Under side setbacks bullet number 9 speaks about our kind of lot which says "In Small Lot Housing Areas, the zero setback may extend over 2 storeys. There is no limit on the length of single storey wall built to a zero lot boundary. However dwelling bulk must take into account impact on solar access to neighbouring properties (Section 1.6) and setbacks (Figure 30)." https://www.campbelltown.nsw.gov.au/files/assets/public/document-resources/builddevelop/planning-policies-and-controls/edmondsonparksouthdevelopmentcontrolplan2012.pdf your lot dimensions are very common in bardia. check what others are doing? keep us updated Re: Building at Bardia - New Breeze 878Aug 07, 2018 3:34 pm mataba Thanks ismSAM Bro, absep19 bro as you suggested I checked @ https://www.campbelltown.nsw.gov.au/Bui ... /DevOnline And I found Assessment in progress Thanks How did you go mate. Did you get approval from council yet? I have been with them for a month now but the horror stories of 3 months or more, i would then embrace to pay monthly penalty to my builder to keep my price intact. I am running out on their timeline end of Oct. Re: Building at Bardia - New Breeze 879Aug 07, 2018 3:39 pm regmiboyer Thanks for replying wentworth33, Is there a document that has more information about the easement. I am refering to the one attached and I read it on ppage 53, Under side setbacks bullet number 9 speaks about our kind of lot which says "In Small Lot Housing Areas, the zero setback may extend over 2 storeys. There is no limit on the length of single storey wall built to a zero lot boundary. However dwelling bulk must take into account impact on solar access to neighbouring properties (Section 1.6) and setbacks (Figure 30)." https://www.campbelltown.nsw.gov.au/files/assets/public/document-resources/builddevelop/planning-policies-and-controls/edmondsonparksouthdevelopmentcontrolplan2012.pdf This is correct, for that reason my builder told me upfront you wont comply with CDC,s o go with council as the DCP states this. So right now, my one side is 700mm away from boundary, both ground and first floor. But since its less that 900mm, its considered zero lot and i cant have windows or any opening on that side. Re: Building at Bardia - New Breeze 880Aug 07, 2018 5:02 pm regmiboyer Thanks for replying wentworth33, Is there a document that has more information about the easement. I am refering to the one attached and I read it on ppage 53, Under side setbacks bullet number 9 speaks about our kind of lot which says "In Small Lot Housing Areas, the zero setback may extend over 2 storeys. There is no limit on the length of single storey wall built to a zero lot boundary. However dwelling bulk must take into account impact on solar access to neighbouring properties (Section 1.6) and setbacks (Figure 30)." https://www.campbelltown.nsw.gov.au/files/assets/public/document-resources/builddevelop/planning-policies-and-controls/edmondsonparksouthdevelopmentcontrolplan2012.pdf Check documents here : https://1drv.ms/f/s!AoKBYVes8JAPjTu-QGBikZCk-1De For reference, this is the Austlii reference. My take on this is, that they would be breaking the law denying access to a homeowner in Victoria, or their agent from having… 1 9082 Is it just a report written to give to the bank initially and it is based on what and how your payments are made up for, or is it a full service where they go out and… 2 5598 Hi Suku18 In NSW the statutory required insurances are: 1. HBCF ( Home Building Compensation Fund) - This is if the builder dies or goes broke. But this only covers 20%… 1 2709 |
