Browse Forums Building Standards; Getting It Right! Re: Patio slab same as house? 2Aug 03, 2018 7:00 am Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Patio slab same as house? 4Aug 04, 2018 7:19 am Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Patio slab same as house? 6Aug 06, 2018 8:13 am Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Patio slab same as house? 8Aug 06, 2018 2:44 pm Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Patio slab same as house? 10Aug 06, 2018 2:58 pm Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Patio slab same as house? 12Aug 06, 2018 3:15 pm Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Patio slab same as house? 14Aug 06, 2018 3:36 pm Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Patio slab same as house? 15Aug 06, 2018 3:56 pm StructuralBIMGuy You have the 2 drop beams separated by insulation & Tied Together? How do you propose to transfers Bending Moments & Stresses? I have a piered slab and piers are not tied together but are on the same footing and reinforced. Re: Patio slab same as house? 17Aug 06, 2018 6:16 pm Thanks for the details, You have a reinforced concrete Wall Tied into the footings Anonamoose unreinforced Brick walls on those footings will be subject to movement, rotation, tensile stresses and cracking and require Bond beams and reinforcement.your cracking will be hidden under the insulating material,,ingress of moisture will be an issue since you don't have a cavity Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Patio slab same as house? 19Aug 06, 2018 6:33 pm i suggest you get a copy of AS3700 masonry codes hth Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Patio slab same as house? 20Aug 12, 2018 8:14 am Hi Everyone, welcome to the conversation alexp79, Interesting conversations! Yes we have plain brick veneer with timber frame. I've discussed the dual slab idea with our builder and he estimates $10k plus engineering for the dual slab idea, does this sound accurate? I am concerned about movement of two relatively independent slabs although other alternatives such as paving may move as well. I never though it would be this hard Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Thanks for your help StructuralBIMGuy and alexp79, we really appreciate you guys taking the time to reply. Thanks for the insights, that makes perfect sense, and yeah, I will be leaning on the experience of the excavator operator entirely. 6 16159 Firstly the ableflex that has been installed needs (manufactures specification) a sealant cap over the top, preventing water draining down between the slab and the… 3 7795 If your patio is going to be 35 sqm then that's going to need Council Approval. The fact that they previously approved your 25sqm patio will be irelevant 1 5511 |
