Browse Forums General Discussion Re: Cladding & insulation 3Aug 01, 2018 4:18 pm meowys Hi All, I am trying to get a better understanding on external wall cladding installation and thermal insulation. When an external cladding material (e.g. weather board) is directly nailed in to timber frames (which are wall wrapped), the nail will penetrate timber frames while piercing the wall wrap. With the number of nails piercing the wall wrap (to hold cladding in place), can this somewhat decrease the wall wrap insulation/ protection ability, in preventing thermal loss and barrier against moisture etc? Is this something to be greatly concerned about? Or maybe the overall impact is negligible? Thanks. interesting scenario ! the cladding material and frame are bad conductor of heat...the impact due to nails into the frame should be negligible. overall the cladding will reduce (compared to brick) the insulation on that side as well. Re: Cladding & insulation 4Aug 01, 2018 6:35 pm IamSAM meowys Hi All, I am trying to get a better understanding on external wall cladding installation and thermal insulation. When an external cladding material (e.g. weather board) is directly nailed in to timber frames (which are wall wrapped), the nail will penetrate timber frames while piercing the wall wrap. With the number of nails piercing the wall wrap (to hold cladding in place), can this somewhat decrease the wall wrap insulation/ protection ability, in preventing thermal loss and barrier against moisture etc? Is this something to be greatly concerned about? Or maybe the overall impact is negligible? Thanks. interesting scenario ! the cladding material and frame are bad conductor of heat...the impact due to nails into the frame should be negligible. overall the cladding will reduce (compared to brick) the insulation on that side as well. Because we are using timber cladding, I've been reading about thermal bridging, so it made me think about this scenario. Re: Cladding & insulation 6Aug 01, 2018 7:25 pm aussieta look up r value brick veneer vs cladding cladding 0.55 r value brick veneer 0.51 r value Hi aussieta, thanks for the info. Actually, my original question relates more to thermal bridging impact between timber frame and cladding. As the nail joining both materials acts as a bridge. Re: Cladding & insulation 8Aug 01, 2018 8:47 pm Although there will be some thermal bridging from the nails, the timber studs themselves are a bigger thermal bridging concern (assuming that you're insulating between the studs - timber is much better thermal conductor than insulation). The practical impact of this will depend on your circumstances, e.g. house size and orientation, climate zone, overall insulation strategy, etc. If you want to avoid thermal bridging altogether, then you'll need to look at either using a different construction than timber frame (e.g. ICF, SIPS) or using an insulating external cladding instead of weatherboard (e.g. EPS). Again, some or all of these options may be overkill for you, depending upon your particular circumstances. Re: Cladding & insulation 9Aug 02, 2018 12:26 am If you are so concerned about thermal bridging caused by studs themselves as well as nails, consider a layer of rigid boards insulation such as XPS or (better) PIR placed in front of the studs. Use composite nails instead of metallic ones to attach the boards to your studs. Place your cladding on top and attach it to the board with the similar composite nails. Re: Cladding & insulation 10Aug 02, 2018 8:59 am meowys With the number of nails piercing the wall wrap (to hold cladding in place), can this somewhat decrease the wall wrap insulation/ protection ability, in preventing thermal loss and barrier against moisture etc? Is this something to be greatly concerned about? Or maybe the overall impact is negligible? Thanks. The surface area of each nail head and impact (Conductance & Transfer) is negligible wood is a poor conductor or energy there is no need to prove this with science, math & FEM illustration/simulation OT, Here is a simulation example for "Shaded & Unshaded Esky with drinks which is used to predict beer temperature in an esky at the beach... BTW the beer temp difference in WA during summer is 2 deg.. LOL no need for an app. Common sense should tell you that you don't need a better esky design Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Standard uninsulated double brick has an R value of around 0.7. An insulated standard 90mm stud timber frame can have an R value of around 2.7. Even if you insulate a… 17 12002 The spacing of the studs looks pretty large especially for a load bearing wall. 3 11106 Re my second point – yes exactly. And often it may take additional time if the manufacturer recommends no more than X meters… 3 5618 |
