Browse Forums General Discussion Re: Fully Porcelain Tiles or Glazed Porcelain Tiles 4Jul 31, 2018 2:21 am SBG14 Thanks for that Alexp79. I have researched the different types of porcelain tiles, but was just wondering what experience people have had with the durability of glazed porcelain tiles after they have been laid. Have they chipped easily or have they been fine, cracked easily or are they fine, maintenance, etc thanks If you go for heavy duty version, they should be good. You can get some top of the range from China for less than US$10 per sqm those days, so it is virtually of the cheapest floor options available (but installation can cost you up to A$60 per sqm). They can go as thin as 4 mm, but probably you would rather go for thicker 10 mm tiles for your flooring. But you should be also looking into insulated slab and hydronic heating if you are seriously planning tiles throughout the house in Victoria. They will be passing temperature directly from the slab. I’m in a similar position except I’m after sliding 3 stacking doors. I am on a second-story apartment of which the balcony would not adequately fit any bi-fold or… 5 16150 I don't know them all, the first 2 top of your list are best known. Rylock is a good company, Stegbar is for sale. 4 16233 Firstly the ableflex that has been installed needs (manufactures specification) a sealant cap over the top, preventing water draining down between the slab and the… 3 7780 |
