Browse Forums Building A New House Re: Coral Homes general build thread 11113Jul 26, 2018 2:04 pm Coral build- Modified Bronte 42 - We're in!!! https://forum.homeone.com.au/viewtopic.php?f=31&t=82234&p=1513775&hilit=coral+modified+bronte#p1513775 Re: Coral Homes general build thread 11118Jul 29, 2018 7:57 pm mpricecs Coral windows by A&L have an in-line reveal, meaning that the glass goes virtually all the way to the frame. When you mount roller blinds in the window you get a massive gap (20mm or so) between the edge of the blind and the frame. In any other window the gap is covered by the part of the windows frame. What have others done to alleviate this problem, other than maybe mount the blinds on the outside of the architrave? For anyone with flyscreens fitted do they help close the gap? Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Damn it ...You are right!!!!! I have a few on order that I can't change now ....grrrrr Coral build- Modified Bronte 42 - We're in!!! https://forum.homeone.com.au/viewtopic.php?f=31&t=82234&p=1513775&hilit=coral+modified+bronte#p1513775 Re: Coral Homes general build thread 11119Jul 30, 2018 10:06 am mpricecs Coral windows by A&L have an in-line reveal, meaning that the glass goes virtually all the way to the frame. When you mount roller blinds in the window you get a massive gap (20mm or so) between the edge of the blind and the frame. In any other window the gap is covered by the part of the windows frame. What have others done to alleviate this problem, other than maybe mount the blinds on the outside of the architrave? For anyone with flyscreens fitted do they help close the gap? Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Ours are the same. When I did the inside frame measurement for blinds, I noticed that the measurement was 176.5 instead of 180cm. I have just bought blinds that fit 180cm and haven't decide if I am going to trim them or mount them on the outside of the frame. The screens make a little difference, but that is only on the side of the window that opens. Re: Coral Homes general build thread 11120Jul 31, 2018 1:51 pm How did everyone go about deducting items charged on the contract that either didn't end up needing to be done, or an allowance for expenses that they may not have used all of? We are requesting a refund of the $2500 listed for the front side retaining wall, which was a just in case sort of addition that Coral forced in, pending site supervisor decision when they got to construction phase. It didn't need to be done so shouldn't be an issue to get that back. We also had listed a few general allowances like removal of spoil, where we were charged $1200 but would like to know how much of that was used, and be refunded any unused money. Plus $3k for additonal building and water approval fees over standard, and $2.5k for on site management which includes fencing that was not utilised. Did you request itemised breakdowns on all of these or accept them? We don't want to be nitpicky but if the money wasn't used we'd like it back. Coral Homes Avoca 20, Providence, Ripley QLD You should check your detail drawings, it may show downpipe within brick pier. 14 14137 Ask the council if there is a chance of getting build over easement exemption. Sometimes easements are unused and 24cm is not all that much. Good luck. And yes any builder… 2 13861 In Qld it is a requirement that a builder must have a cost breakdown, for building a home to the same specification, with the same inclusions and the same finish. So ask… 1 4361 |
