Browse Forums Building A New House Re: Who else is building with Eden Brae? 15121Jun 21, 2018 9:09 am Current State: Slab/Frame/Bricklayer/Lockup/Lining/Stairs/Kitchen/Wet flooring/Painted/PCI/Got the Keys My Thread: Building Windsor 40 with Eden Brae (Caddens) Re: Who else is building with Eden Brae? 15123Jun 21, 2018 2:38 pm Current State: Slab/Frame/Bricklayer/Lockup/Lining/Stairs/Kitchen/Wet flooring/Painted/PCI/Got the Keys My Thread: Building Windsor 40 with Eden Brae (Caddens) Re: Who else is building with Eden Brae? 15127Jul 12, 2018 8:34 pm Current State: Slab/Frame/Bricklayer/Lockup/Lining/Stairs/Kitchen/Wet flooring/Painted/PCI/Got the Keys My Thread: Building Windsor 40 with Eden Brae (Caddens) Re: Who else is building with Eden Brae? 15129Jul 13, 2018 8:46 am Current State: Slab/Frame/Bricklayer/Lockup/Lining/Stairs/Kitchen/Wet flooring/Painted/PCI/Got the Keys My Thread: Building Windsor 40 with Eden Brae (Caddens) Re: Who else is building with Eden Brae? 15131Jul 14, 2018 8:42 am Current State: Slab/Frame/Bricklayer/Lockup/Lining/Stairs/Kitchen/Wet flooring/Painted/PCI/Got the Keys My Thread: Building Windsor 40 with Eden Brae (Caddens) Re: Who else is building with Eden Brae? 15136Jul 16, 2018 5:13 pm Nekual I have this idea for kitchen instead of a fixed Pullout waste bin house, would cabinetry builders entertain a portable waste unit on rollers housed in the kitchen/island , but can be extract fully anytime. like wheel it around the kitchen or to the council bins outside the house. If they wont, they can leave a cabinet out (as in the case of a dishwasher space) then you could get one made post handover. It might make your kickboard look strange though. Re: Who else is building with Eden Brae? 15137Jul 28, 2018 6:55 pm Hi All, Anyone had variations (PCV) for the BASIX? Do you know how "A/C zoned day/night between living/bedroom zones (AC can only operate in the living area zones during the day and bedroom zones at night)" works? Anyone selected this option? Thanks Current State: Slab/Frame/Bricklayer/Lockup/Lining/Stairs/Kitchen/Wet flooring/Painted/PCI/Got the Keys My Thread: Building Windsor 40 with Eden Brae (Caddens) Re: Who else is building with Eden Brae? 15138Jul 29, 2018 9:16 am InvincibleInDN Hi All, Anyone had variations (PCV) for the BASIX? Do you know how "A/C zoned day/night between living/bedroom zones (AC can only operate in the living area zones during the day and bedroom zones at night)" works? Anyone selected this option? Thanks Day/Night usually means you have 2 zones and probably the system is designed to run 1 of the 2 zones at any one time. Generally speaking if you work on 2kw per outlet gives you an idea of what capacity unit you require. Re: Who else is building with Eden Brae? 15139Jul 29, 2018 9:20 am Waigo Day/Night usually means you have 2 zones and probably the system is designed to run 1 of the 2 zones at any one time. Generally speaking if you work on 2kw per outlet gives you an idea of what capacity unit you require. Thank you waigo. The unit we selected is 19.5kW and 7 zones. Bedrooms and living areas are separated by these zones. BASIX site just talks about just zoning. What I we want to know is, should we have to do more than zoning for this? Current State: Slab/Frame/Bricklayer/Lockup/Lining/Stairs/Kitchen/Wet flooring/Painted/PCI/Got the Keys My Thread: Building Windsor 40 with Eden Brae (Caddens) Re: Who else is building with Eden Brae? 15140Jul 29, 2018 9:22 am InvincibleInDN Waigo Day/Night usually means you have 2 zones and probably the system is designed to run 1 of the 2 zones at any one time. Generally speaking if you work on 2kw per outlet gives you an idea of what capacity unit you require. Thank you waigo. The unit we selected is 19.5kW and 7 zones. Bedrooms and living areas are separated by these zones. BASIX site just talks about just zoning. What I we want to know is, should we have to do more than zoning for this? No Basix just says you need to have at least 2 zones. If you have 7 zones it will be fine as that is better than 2 as you can only run areas you are using which is better for energy consumption generally. I built with EB back on 2009. Check out this thread on this forum. viewtopic.php?f=31&t=12911&p=154061#p154061 I can't speak for recent expericience however, we had no… 1 24058 A survey must’ve completed by a certified surveyor. This form part of every DA requirement 3 226308 |
