Browse Forums General Discussion Re: Retaining wall issue with my neighbour.... 3Jul 13, 2018 10:36 am I certainly wouldn't be rushed into anything because of a letter - or threats in it. Were your "discussions" in writing - do you have emails etc ? These things happen - but remember - you do want to remain on good terms with neighbours. BUT - watch out for the bully who thinks you being "nice" is a weakness. Re: Retaining wall issue with my neighbour.... 4Mar 12, 2019 10:51 am Hi Nasif, Retaining wall the responsibility of that neighbour who's land level is below. however some times if neighbour is friendly and willing to pay for it then its different case. I'd recommend you to go with 200x80 mm slippers under neath is and thats it it will work as retaining wall. there is not much difference in 200x80mm (heavy duty) slipper and retaining wall other then post distance Im not expert but gone through with same situation and my builder friend suggest this. Also i have DIY added few 1.5 meters steel post half under the fence and top portion screwed with fence base to add some more durability to my fence. Re: Retaining wall issue with my neighbour.... 5Mar 12, 2019 11:54 am gabereal Hi Nasif, Retaining wall the responsibility of that neighbour who's land level is below. however some times if neighbour is friendly and willing to pay for it then its different case. I'd recommend you to go with 200x80 mm slippers under neath is and thats it it will work as retaining wall. there is not much difference in 200x80mm (heavy duty) slipper and retaining wall other then post distance Im not expert but gone through with same situation and my builder friend suggest this. Also i have DIY added few 1.5 meters steel post half under the fence and top portion screwed with fence base to add some more durability to my fence. "Retaining wall the responsibility of that neighbour who's land level is below." - This is not factually correct. The party responsible for changing the natural fall is liable to bear the cost of retaining wall. An adjoining owner can seek a contribution for the carrying out of work to a retaining wall where the wall is necessary for the support and maintenance of a dividing fence - This applies where no change has been made (cut-fill) to the natural slope of the land. Thank you again Simeon.. I will call my certifier for that. Have a good day 4 5197 thanks Chippy, i hope they have applied sealer but i am doubt to be honest, so i am gonna do this job after handover. 8 16294 Thanks for the insights, that makes perfect sense, and yeah, I will be leaning on the experience of the excavator operator entirely. 6 16157 |
