Browse Forums Building A New House Re: Building with Wisdom Homes 11524Jul 11, 2018 12:20 pm Building the Washington 29 with Wisdom Homes Re: Building with Wisdom Homes 11529Jul 11, 2018 1:54 pm ASJ1981 Hi everyone, when we receive draft end panel, at this stage can we still change the Landscaping PA? I signed off on the Quote, but planning to delete the $2,900 for removal of fill. TIA! Our experience we had a PA provided during selection appointments however never added to EP. During construction you meet the landscaping team onsite and walkthrough exactly what you need and a quote is provided. You can then add/delete items. Once signed off the cost is then added to contract and that amount is payable when you receive keys. Building WH Manhattan 44 Ensuite Production Estimates: 13 Nov 2017 DA Approval : 25 October 2017 Contract Sign: 28 May 2017 Tender Sign: 24 April 2017 Request for Tender: 22 Jan 2017 Re: Building with Wisdom Homes 11530Jul 11, 2018 2:01 pm lombieagle ASJ1981 Hi everyone, when we receive draft end panel, at this stage can we still change the Landscaping PA? I signed off on the Quote, but planning to delete the $2,900 for removal of fill. TIA! Our experience we had a PA provided during selection appointments however never added to EP. During construction you meet the landscaping team onsite and walkthrough exactly what you need and a quote is provided. You can then add/delete items. Once signed off the cost is then added to contract and that amount is payable when you receive keys. Thank you lombieagle. Am planning to delete just this item from the Landscaping Quote before we sign the EP. Re: Building with Wisdom Homes 11531Jul 11, 2018 2:08 pm ASJ1981 lombieagle ASJ1981 Hi everyone, when we receive draft end panel, at this stage can we still change the Landscaping PA? I signed off on the Quote, but planning to delete the $2,900 for removal of fill. TIA! Our experience we had a PA provided during selection appointments however never added to EP. During construction you meet the landscaping team onsite and walkthrough exactly what you need and a quote is provided. You can then add/delete items. Once signed off the cost is then added to contract and that amount is payable when you receive keys. Thank you lombieagle. Am planning to delete just this item from the Landscaping Quote before we sign the EP. At this stage for you it’s only a PA. A quote is provided when you meet the landscaping team onsite during construction. The PA is provided if you need the amount included if borrowing funds. If this is the case for you I would leave it as is until you have onsite meeting for quote. May give a buffer for items you never considered in PA. Building WH Manhattan 44 Ensuite Production Estimates: 13 Nov 2017 DA Approval : 25 October 2017 Contract Sign: 28 May 2017 Tender Sign: 24 April 2017 Request for Tender: 22 Jan 2017 Re: Building with Wisdom Homes 11532Jul 11, 2018 2:09 pm Jenifermarie We didn’t have many questions but we did take a while to really make sure we documented where all the wires etc are in the walls and that everything was in the right place for electrical. Main things we picked up were - power points not at the right height to hide in our bathroom vanities - some wall blocking not installed for TV mounting/heavy mirrors - ceiling blocking not installed for large pendants (we added these at electrical) Another thing to check is the framing where all the ducting for AC has been put in. These aren’t on the construction plans although we got an email showing us where they had put all the ducts after rough in. We had an issue with one - we expected it to be built out flush with the nib wall so it wasn’t obvious, but instead it was stepped back which we weren’t happy with. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ The rest of them were all hidden in wardrobes so we had no issue with those. Building Wisdom Aspiration 31 at Willowdale https://ourwillowdalehome.wordpress.com/ Thanks Kazi for asking and Jenifermarie for the advice. We are just post-contract so still selecting things but should we have provisioned for supports by now? We discussed supports for the chandelier during the electrical consult. On a similar vein, we are having tiles to our media alcove where the TV and fireplace will be (not cantilever but inbuilt), is there anything I need to know about mounting a TV to tiles? Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ We are having joinery on either side of a tiled centre. Re: Building with Wisdom Homes 11533Jul 11, 2018 2:10 pm ASJ1981 Hi everyone, when we receive draft end panel, at this stage can we still change the Landscaping PA? I signed off on the Quote, but planning to delete the $2,900 for removal of fill. TIA! On our meeting we asked for few different quotes on exactly what items we want now to be done by Wisdom. E.g. one quote with brick piering fencing, another quote with timber slipper fencing. He sent us all fresh quotes after assessing the current status of the site. Luckily it came down from initial for us. We signed on it last night as it needs to be signed off before gyprock. Building Ambassador 41 Wisdom Homes Slab done 19 March 2018 Frame done 20 April 2018 Bricks done 31 May 2018 [i][i][i]Building Ambassador 41 Wisdom Homes[/i][/i][/i] Re: Building with Wisdom Homes 11534Jul 11, 2018 2:32 pm becks81 Jenifermarie We didn’t have many questions but we did take a while to really make sure we documented where all the wires etc are in the walls and that everything was in the right place for electrical. Main things we picked up were - power points not at the right height to hide in our bathroom vanities - some wall blocking not installed for TV mounting/heavy mirrors - ceiling blocking not installed for large pendants (we added these at electrical) Another thing to check is the framing where all the ducting for AC has been put in. These aren’t on the construction plans although we got an email showing us where they had put all the ducts after rough in. We had an issue with one - we expected it to be built out flush with the nib wall so it wasn’t obvious, but instead it was stepped back which we weren’t happy with. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ The rest of them were all hidden in wardrobes so we had no issue with those. Building Wisdom Aspiration 31 at Willowdale https://ourwillowdalehome.wordpress.com/ Thanks Kazi for asking and Jenifermarie for the advice. We are just post-contract so still selecting things but should we have provisioned for supports by now? We discussed supports for the chandelier during the electrical consult. On a similar vein, we are having tiles to our media alcove where the TV and fireplace will be (not cantilever but inbuilt), is there anything I need to know about mounting a TV to tiles? Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ We are having joinery on either side of a tiled centre. Just use a drill bit that is meant for tiles, that's all really and make sure you drill into wood frame out the back. Re: Building with Wisdom Homes 11535Jul 11, 2018 7:47 pm Had our pre-lining meeting in 18 week today. Met our Site Supervisor. Such a wonderful person! Couldn't find much fault. SS has put timber support in most of the room ceiling (upstairs and downstairs) for my possible ceiling fan option. He is arranging re-direction of wiring for future ceiling fan. Timber support all ok for TV wall mount in all possible locations (Home theater, living downstairs, upstairs leisure). Also in entry for large wall mirror. Only 2 things I picked up or requested: - Dining pendant point closer to wall (currently in the centre of room) - Master suite media alcove power point need to be raised in bench height (I asked in electrical appoitmemt) since I will have custom wall mount joinery and mirror on that wall (a dressing table kind of). Forecast: 19 week: Gyprock complete 20 week: Stairs complete 22 week: kitchen complete 30 week: Handover Finger crossed Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Building Ambassador 41 Wisdom Homes Slab done 19 March 2018 Frame done 20 April 2018 Bricks done 31 May 2018 [i][i][i]Building Ambassador 41 Wisdom Homes[/i][/i][/i] Re: Building with Wisdom Homes 11536Jul 11, 2018 8:01 pm singalg Kazi After Week 17: Scaffold removed and rebuilt Lower roof done Rough ins all to be in week 18 Insulation to be in week 19 Pre linings meeting to be early week 19 Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Building Ambassador 41 Wisdom Homes Slab done 19 March 2018 Frame done 20 April 2018 Bricks done 31 May 2018 Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Great progress Kazi. Noticed that the front eaves are not done yet, but the rest of the eaves and downpipes have been painted? Is that how it should be? In our pre-lining meeting today in 18 weeks the eves are all done. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Building Ambassador 41 Wisdom Homes Slab 19 Mar 2018 Frame 20 Apr 2018 Bricks 01- 31 May 2018 Gyprock 13-17 Jul 2018 [i][i][i]Building Ambassador 41 Wisdom Homes[/i][/i][/i] Re: Building with Wisdom Homes 11537Jul 11, 2018 8:21 pm Kazi singalg Kazi After Week 17: Scaffold removed and rebuilt Lower roof done Rough ins all to be in week 18 Insulation to be in week 19 Pre linings meeting to be early week 19 Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Building Ambassador 41 Wisdom Homes Slab done 19 March 2018 Frame done 20 April 2018 Bricks done 31 May 2018 Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Great progress Kazi. Noticed that the front eaves are not done yet, but the rest of the eaves and downpipes have been painted? Is that how it should be? In our pre-lining meeting today in 18 weeks the eves are all done. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Building Ambassador 41 Wisdom Homes Slab 19 Mar 2018 Frame 20 Apr 2018 Bricks 01- 31 May 2018 Gyprock 13-17 Jul Awesome progress Kazi We are still awaiting CDC approval unfortunately and desperately need draft end panel for the bank for Friday but looks like that won’t happen either! Re: Building with Wisdom Homes 11538Jul 11, 2018 9:00 pm Thanks for the photos Kazi, I noticed the eaves too . Your house is looking fantastic! I believe you are counting the weeks from Site Scraping? We are in week 17 from Site Scraping, and expecting Eaves to go in this week, and downpipes + Eaves painted next week. So at the end of Week 18, we will have Eaves, downpipes completed, and bricks cleaned. So I think a little bit behind schedule. Maj-35 Tend:14/7/17,Cont:18/8/17,DA:9/1/18,DEP:1/2,Const:8/3, Slab: 28/3,Frames:17/4-23/4,Bricks:22/5-14/6,URoof: 29/6,elec:4/8,AC,GRoof:11/8,gyp:24/08,Keys:4/12,move:16/12 Re: Building with Wisdom Homes 11539Jul 11, 2018 9:13 pm Hi siagalg, Yes our site was scraped on 06 March 2018 and that should be our 0th day count in construction stage, 13 March 2018 being week 1. As per SS, week 18 is 10 July 2018. singalg Thanks for the photos Kazi, I noticed the eaves too . Your house is looking fantastic! I believe you are counting the weeks from Site Scraping? We are in week 17 from Site Scraping, and expecting Eaves to go in this week, and downpipes + Eaves painted next week. So at the end of Week 18, we will have Eaves, downpipes completed, and bricks cleaned. So I think a little bit behind schedule. Building Ambassador 41 Wisdom Homes Slab 19 Mar 2018 Frame 20 Apr 2018 Bricks 01- 31 May 2018 Gyprock 13-17 Jul 2018 [i][i][i]Building Ambassador 41 Wisdom Homes[/i][/i][/i] Re: Building with Wisdom Homes 11540Jul 11, 2018 9:38 pm Kazi Hi siagalg, Yes our site was scraped on 06 March 2018 and that should be our 0tf day count in construction stage. As per SS week 18 is 10 July 2018. singalg Thanks for the photos Kazi, I noticed the eaves too . Your house is looking fantastic! I believe you are counting the weeks from Site Scraping? We are in week 17 from Site Scraping, and expecting Eaves to go in this week, and downpipes + Eaves painted next week. So at the end of Week 18, we will have Eaves, downpipes completed, and bricks cleaned. So I think a little bit behind schedule. Building Ambassador 41 Wisdom Homes Slab 19 Mar 2018 Frame 20 Apr 2018 Bricks 01- 31 May 2018 Gyprock 13-17 Jul 2018 That's good to know. Thanks Kazi Maj-35 Tend:14/7/17,Cont:18/8/17,DA:9/1/18,DEP:1/2,Const:8/3, Slab: 28/3,Frames:17/4-23/4,Bricks:22/5-14/6,URoof: 29/6,elec:4/8,AC,GRoof:11/8,gyp:24/08,Keys:4/12,move:16/12 Can someone please offer some advice? Im DESPERATE. Because I'm completely and utterly exhausted. How long are variations taking with other companies at the moment? We… 0 19720 In fairness nobody gave a crap about the ACCC and the gag clauses continued in the pro forma templates of a few other builders after the ACCC took on Wisdom, and more… 19 75485 Hi Everyone, I am exploring builder in NSW and received a very tempting quote from Wisdom home for their momentum series. I just want to know experience of building… 0 9961 |
