Browse Forums Building A New House Re: Height compliance questions. Did you encounter this? 6Jul 15, 2018 3:20 pm One error I can see in your calculations: you're taking 360mm off the height for the cut. That's not consistent with what's on the plan provided, which only has that depth of cut at the extreme bottom right, and has fill in other areas. Your benching is at 70.34, which means even with the dimensions listed in your calculation, your roof apex is going to be just above 8.5 metres at the left above the natural contours provided. Due to the fall of the land, moving the house to the left looks like it'll increase how high that point is above the natural ground level. Re: Height compliance questions. Did you encounter this? 7Jul 15, 2018 3:34 pm algernon One error I can see in your calculations: you're taking 360mm off the height for the cut. That's not consistent with what's on the plan provided, which only has that depth of cut at the extreme bottom right, and has fill in other areas. Your benching is at 70.34, which means even with the dimensions listed in your calculation, your roof apex is going to be just above 8.5 metres at the left above the natural contours provided. Due to the fall of the land, moving the house to the left looks like it'll increase how high that point is above the natural ground level. Building Height: 8230mm 2740mm Ground Floor 250mm Sub Floor 2590mm First Floor 2650mm 25° Roof pitch Natural Ground Level in area of Roof Apex: RL 70.40m Slab height: 310mm Height inc slab & building 8540mm Ground Level after cut and fill: RL 70.34m Hence, building height in relation to ground level: Ground Level 70.40m before cut. Reduced Level:69.80m (70.40m less 0.6m cut) Cut at apex is 60mm below natural ground level. Building height including slab: 8540mm less 60mm cut in area of Apex. Building height in relation to ground level: 8480mm. For anyone that comes across this issue in the future - Just did what aussieta said and found a plumber to inspect it and sign off on it. Was difficult to find someone to… 3 7037 From a pure legal perspective, if you've signed the variation, it is a very high bar to have it set aside. No-one can give you legal advice on a forum, but you would need… 3 5478 |
