Browse Forums Building A New House Re: Building with Metricon 7474Jul 09, 2018 6:08 pm blackcat20 excited_builders Who checks the electrical rough ins before bricks n plaster boards are put? We have 1wire that is missed being pulled out of the brick wall on the laundry side. But I wanted to know who normally checks that the electricals are as per the plan....is it the independent Inspector or me? Re: Building with Metricon 7475Jul 09, 2018 6:13 pm excited_builders blackcat20 excited_builders Who checks the electrical rough ins before bricks n plaster boards are put? We have 1wire that is missed being pulled out of the brick wall on the laundry side. But I wanted to know who normally checks that the electricals are as per the plan....is it the independent Inspector or me? Re: Building with Metricon 7476Jul 10, 2018 7:41 am stoff17 mickym Anyone had M build with brick veneer downstairs and hebel upstairs? Yeah we have. Originally weatherboard but upgraded upperstory to hebel. Bout a $8k upgrade by memory ok thanks, we've been told that brick veneer downstairs and hebel upstaris is not possible, the whole house must be hebel, did you get any resistance? Re: Building with Metricon 7477Jul 10, 2018 7:55 am Ducted reverse cycle heating and cooling We are building a double story 45sq house and have a question about the ducted reverse cycle heating/cooling system. We got a preliminary estimate of 29k, which seems to be about the mark. However in our plan, there isn't drop points between the first and ground floors for the return air grill only upstairs. M have told us its not needed, we are getting 2 separate units one for each floor with zoning. I thought this was suspect having know enough about this so I sought independent advice which tells me that we need at least 2 return grills downstairs to efficient run the unit and move air around. Can anyone else share their experiance/setup/process with M? Re: Building with Metricon 7478Jul 10, 2018 7:58 am madj-m stoff17 mickym Anyone had M build with brick veneer downstairs and hebel upstairs? Yeah we have. Originally weatherboard but upgraded upperstory to hebel. Bout a $8k upgrade by memory ok thanks, we've been told that brick veneer downstairs and hebel upstaris is not possible, the whole house must be hebel, did you get any resistance? Re: Building with Metricon 7479Jul 10, 2018 8:15 am We had no resistance at all. When I asked, it was a straight yes and just waited back on pricing. So not sure why they are rejecting your request. I’ve also got a mate that is about to go to site and he has done the same thing without any hassle Re: Building with Metricon 7480Jul 10, 2018 8:29 am madj-m stoff17 mickym Anyone had M build with brick veneer downstairs and hebel upstairs? Yeah we have. Originally weatherboard but upgraded upperstory to hebel. Bout a $8k upgrade by memory ok thanks, we've been told that brick veneer downstairs and hebel upstaris is not possible, the whole house must be hebel, did you get any resistance? They reject it because they're lazy, it takes rework with the drafting and estimates team which they'd prefer not to do. If you insist that's what you want they'll get it done. Ours was all Hebel and we were told the same thing, couldn't even have the top corner as weatherboard (to break up the elements abit). Once it went for developer approval, they came back saying we needed to add weatherboard in the exact spot we wanted (for the same reason, to break it up), and M did it 😂 Hi, First of all, thank you to this community for sharing your thoughts and opinions. We are in early days of our pre-contract stage for Metricon Doulton and we are… 0 11418 Hello All 🙂 We are planning to start our journey of construction our first home. We zeroed down on Metricon and henley homes based on design suitable for our lot and… 0 8827 We don’t live in VIC so want to know the exterior colours of Lumiere display so we can see it at the paint shop. Not building with Metricon so my request went… 0 18752 |
