Browse Forums Pools & Spas Re: How to deal with excess water when pool is lower than st 6Jun 22, 2018 11:34 pm 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: How to deal with excess water when pool is lower than st 9Jul 07, 2018 11:52 pm Hi, These are actually not accepted by Brisbane City Council any more. I'm in Aspley. Re: How to deal with excess water when pool is lower than st 10Jul 08, 2018 8:28 am gaweleczek These are actually not accepted by Brisbane City Council any more. That is also my understanding with rubble pits plus pools should also not be drained to stormwater because of their chemical and/or salt content. There are different regulatory bodies to check, the EPA being one of them. Can it be pumped to a holding tank for later (gravity fed) reuse? 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: How to deal with excess water when pool is lower than st 11Jul 08, 2018 5:17 pm As long as you're draining less than 5% of your pools water in a controlled manner.. you can drain to stormwater. To make it controlled, put a 2 way valve in line, between the pool and the storm entry. PM me your email. I have a build excavation calculator you can use based on your plans to double check what your builder is telling you. Cheers Simeon 1 10373 Hi there, We’ve recently had plans approved to add a 1st storey addition to our existing house for a growing family in Sydney. With the current cost of building… 0 4506 I am looking to design an entry door to a lower ground basement that has 2200mm between the external entry height to FFL of the ground floor. This door will provide an… 0 12167 |
