Even the little wardrobe in the guest bedroom should have skirts and carpet too.
Browse Forums Building A New House Re: Building with Metricon 7432Jul 04, 2018 8:14 pm Doulton777 Kandi Now I am worried too. when you say secure what is that means? it was mentioned in our report "plumbing penetrations are only partially silicone in areas, check and complate all penetrations" is this what you are talking about? we don't know this been fixed or not I’m not sure the terminology they use. All I know is that my private inspector went around and checked how tight the pipes were done. If they aren’t secured enough and felt loose. Then the plumbers would have to tighten them. But when he pulled on ours. He was surprised it wasn’t loose. Cos he reckons a lot of times when it’s not. You can hear a vibration in the wall. And that’s because it wouldn’t have been installed correctly. viewtopic.php?t=86597 Thanks Doulton. So this has to be done before Gybrock? can not fix after? Re: Building with Metricon 7433Jul 04, 2018 8:33 pm Doulton777 emmyawards Doulton777 [quote="excited_builders"]We finished our pre plaster inspection last Thursday all was in order except for the plumber needing to secure the water pipes so no hammering occurs when water passes through. We have had a lot of progress since then ...there were 15 people inside the house and 10 people outside doing the Bricks. The plaster is completed with only the edges and gaps to be fine tuned. Bricks are well underway. Pics to follow..... Apparently it’s quiet common for the pipes to be loose. My private inspector was surprised when ours were solid in there. As he said quiet often they don’t tighten it. viewtopic.php?t=86597 Oh man now I’m worried about my pipes! Did you get your private inspector to check them? viewtopic.php?t=86597[/quote] I did have a private inspector but I don’t know if they went around shaking pipes!! Re: Building with Metricon 7434Jul 04, 2018 9:42 pm You don't get water hammer in poly pipes... Unless youe house is all copper pipe, the independent inspector is wasting your money Our Bayside KDR Thread: viewtopic.php?f=31&t=78298 Re: Building with Metricon 7435Jul 05, 2018 1:13 am Kandi Doulton777 Kandi Now I am worried too. when you say secure what is that means? it was mentioned in our report "plumbing penetrations are only partially silicone in areas, check and complate all penetrations" is this what you are talking about? we don't know this been fixed or not I’m not sure the terminology they use. All I know is that my private inspector went around and checked how tight the pipes were done. If they aren’t secured enough and felt loose. Then the plumbers would have to tighten them. But when he pulled on ours. He was surprised it wasn’t loose. Cos he reckons a lot of times when it’s not. You can hear a vibration in the wall. And that’s because it wouldn’t have been installed correctly. viewtopic.php?t=86597 Thanks Doulton. So this has to be done before Gybrock? can not fix after? It’s best to be checked beforehand. I don’t know how they go about fixing it later. But I can imagine it will be a lot of hassles. viewtopic.php?t=86597 Re: Building with Metricon 7436Jul 05, 2018 8:39 am Doulton777 Kandi Doulton777 [quote="Kandi"]Now I am worried too. when you say secure what is that means? it was mentioned in our report "plumbing penetrations are only partially silicone in areas, check and complate all penetrations" is this what you are talking about? we don't know this been fixed or not I’m not sure the terminology they use. All I know is that my private inspector went around and checked how tight the pipes were done. If they aren’t secured enough and felt loose. Then the plumbers would have to tighten them. But when he pulled on ours. He was surprised it wasn’t loose. Cos he reckons a lot of times when it’s not. You can hear a vibration in the wall. And that’s because it wouldn’t have been installed correctly. viewtopic.php?t=86597 Thanks Doulton. So this has to be done before Gybrock? can not fix after? It’s best to be checked beforehand. I don’t know how they go about fixing it later. But I can imagine it will be a lot of hassles. viewtopic.php?t=86597[/quote] and I can’t even ask my inspector cause he left the company. Re: Building with Metricon 7437Jul 05, 2018 8:41 am emmyawards and I can’t even ask my inspector cause he left the company. Based on Drew's comment theres no need if you have plastic pipes. Re: Building with Metricon 7438Jul 05, 2018 9:56 am blackcat20 emmyawards and I can’t even ask my inspector cause he left the company. Based on Drew's comment theres no need if you have plastic pipes. I don’t know what everyone else got. But we got copper. That’s what I saw him check. viewtopic.php?t=86597 Re: Building with Metricon 7439Jul 05, 2018 9:56 am emmyawards Doulton777 Kandi [quote="Doulton777"][quote="Kandi"]Now I am worried too. when you say secure what is that means? it was mentioned in our report "plumbing penetrations are only partially silicone in areas, check and complate all penetrations" is this what you are talking about? we don't know this been fixed or not I’m not sure the terminology they use. All I know is that my private inspector went around and checked how tight the pipes were done. If they aren’t secured enough and felt loose. Then the plumbers would have to tighten them. But when he pulled on ours. He was surprised it wasn’t loose. Cos he reckons a lot of times when it’s not. You can hear a vibration in the wall. And that’s because it wouldn’t have been installed correctly. viewtopic.php?t=86597 Thanks Doulton. So this has to be done before Gybrock? can not fix after? It’s best to be checked beforehand. I don’t know how they go about fixing it later. But I can imagine it will be a lot of hassles. viewtopic.php?t=86597[/quote] and I can’t even ask my inspector cause he left the company. [/quote] Do you know if you got copper or plastic? viewtopic.php?t=86597 Re: Building with Metricon 7440Jul 05, 2018 10:02 am The only copper piping in our house before they sheeted it was for coolant lines to the heating/cooling... Most unusual for copper to be used for water these days Our Bayside KDR Thread: viewtopic.php?f=31&t=78298 Hi, First of all, thank you to this community for sharing your thoughts and opinions. We are in early days of our pre-contract stage for Metricon Doulton and we are… 0 11486 Hello All 🙂 We are planning to start our journey of construction our first home. We zeroed down on Metricon and henley homes based on design suitable for our lot and… 0 8905 We don’t live in VIC so want to know the exterior colours of Lumiere display so we can see it at the paint shop. Not building with Metricon so my request went… 0 18915 |
