Browse Forums Building A New House Re: Building with Wisdom Homes 11382Jul 01, 2018 10:14 pm becks81 Re : electrical consult. If we want downlight provisions and outdoor flood light provisions, what exactly do they do and what will we need to purchase on our end? We will probably get WH to install some of our lighting but not all of it. And what is the consensus about downlights in bedrooms? For downlight provision, they will cut the hole, run the wiring and terminate each downlight hole with a 3-pin socket. You'll need to buy the downlight with the normal power plug. For flood light provision they will terminate to a batten. Just need to get an electrician to install your flood light after handover. We have downlights all over the house, I think about 90 altogether. I do like bright rooms. Wisdom Homes Manhattan 39 Blog - https://edmondson-park.blogspot.com.au H1 Thread - https://forum.homeone.com.au/viewtopic.php?f=31&t=88210 Re: Building with Wisdom Homes 11383Jul 01, 2018 10:29 pm GLO Out of curiosity, what month did you all sign your contract and how long after that did it take for your slab to go down? Thanks in advance to everyone that replies. lombieagle Signed contract in May 17 slab completed 30 Nov 17 Jenifermarie Signed April 17, slab Feb 18. We had a 3 month delay in land registration jqcc0 Signed 10th November 2017. Slab should go down sometime this month hopefully. Thanks for your replies! Was it so long due to council delays? Has anyone had their slab down in 3months for a registered block and everything on their end sorted like colour selection and through CDC? And once the slab goes down how long till the frames go up? Thanks Re: Building with Wisdom Homes 11384Jul 01, 2018 10:32 pm GLO GLO Out of curiosity, what month did you all sign your contract and how long after that did it take for your slab to go down? Thanks in advance to everyone that replies. lombieagle Signed contract in May 17 slab completed 30 Nov 17 Jenifermarie Signed April 17, slab Feb 18. We had a 3 month delay in land registration jqcc0 Signed 10th November 2017. Slab should go down sometime this month hopefully. Thanks for your replies! Was it so long due to council delays? Has anyone had their slab down in 3months for a registered block and everything on their end sorted like colour selection and through CDC? And once the slab goes down how long till the frames go up? Thanks Contract signing- slab for us was 5.5 months. Would’ve been 4.5 if we hadn’t made changes. Don’t think it will happen much faster than that. That was CDC approval which was very fast. Building Monte Carlo 40- Wisdom homes Re: Building with Wisdom Homes 11385Jul 02, 2018 1:42 pm Hi GLO, Our time lines for you- Building Ambassador 41 Wisdom Homes Completion Dates: Contract Sign 14 Oct 2017 End Panel 07 Feb 2018 Prod. Estimate 28 Feb 2018 Const. release 14 Mar 2018 Slab 19 Mar 2018 Frame 20 Apr 2018 Scaffold 15 May 2018 Upper roof 24 May 2018 Bricks 04-31 May 2018 Bricks clean 09 Jun 2018 Cladding, Eves 13 Jun 2018 Painting, Render 21 Jun 2018 Scaffold rebuild 29 Jun 2018 Fascia, Gutter, Lower roof 05 Jul 2018 [i][i][i]Building Ambassador 41 Wisdom Homes[/i][/i][/i] Re: Building with Wisdom Homes 11386Jul 02, 2018 2:13 pm [i][i][i][i]Can anyone help me with Home One's signature issue? [/i][/i][/i][/i] [i][i][i][i]Why can I not add more lines in signature and why are these following notations ??[/i][/i][/i][/i] [i][i][i][i][i][i][i][i] [/i][/i][/i][/i][/i][/i][/i][/i] [i][i][i]Building Ambassador 41 Wisdom Homes[/i][/i][/i] Re: Building with Wisdom Homes 11387Jul 02, 2018 2:32 pm i suppose there is a limitation..afterall its a signature try entering 2 status in one row, as shown below.. Contract Sign 14 Oct 2017 End Panel 07 Feb 2018 Prod. Estimate 28 Feb 2018 Const. release 14 Mar 2018 That will reduce number of rows.. Re: Building with Wisdom Homes 11388Jul 02, 2018 2:34 pm The notations are everywhere in my previous post! I know there must a space limit but I was able to have few lines of our build timelines before in my signature, but now I can not. No worries I am trying to figure out, thanks [i][i][i]Building Ambassador 41 Wisdom Homes[/i][/i][/i] Re: Building with Wisdom Homes 11391Jul 02, 2018 4:03 pm Jenifermarie The gyprock rumour was true, won’t lie I was pretty shocked as I didn’t believe it could be done that quick. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ The house next door finally finished rendering and painting this week...it’s a towering blinding cube Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Building Wisdom Aspiration 31 at Willowdale https://ourwillowdalehome.wordpress.com/ That’s awesome, looks great!! Re: Building with Wisdom Homes 11392Jul 02, 2018 4:16 pm GLO GLO Out of curiosity, what month did you all sign your contract and how long after that did it take for your slab to go down? Thanks in advance to everyone that replies. lombieagle Signed contract in May 17 slab completed 30 Nov 17 Jenifermarie Signed April 17, slab Feb 18. We had a 3 month delay in land registration jqcc0 Signed 10th November 2017. Slab should go down sometime this month hopefully. Thanks for your replies! Was it so long due to council delays? Has anyone had their slab down in 3months for a registered block and everything on their end sorted like colour selection and through CDC? And once the slab goes down how long till the frames go up? Thanks I think it’s possible if everything goes smoothly. We bought registered land too, and I felt everything tracked reasonably quick through admin. We signed tender & contract on 20th Feb CDC approval was on 10th May DEP 16th May Currently still stuck with the agreement of payment schedule.. between broker/bank & wisdom’s CSR manager.. so almost 7 weeks have gone by ☹️ Re: Building with Wisdom Homes 11393Jul 02, 2018 6:49 pm Kazi Hi GLO, Our time lines for you- Building Ambassador 41 Wisdom Homes Completion Dates: Contract Sign 14 Oct 2017 End Panel 07 Feb 2018 Prod. Estimate 28 Feb 2018 Const. release 14 Mar 2018 Slab 19 Mar 2018 Frame 20 Apr 2018 Scaffold 15 May 2018 Upper roof 24 May 2018 Bricks 04-31 May 2018 Bricks clean 09 Jun 2018 Cladding, Eves 13 Jun 2018 Painting, Render 21 Jun 2018 Scaffold rebuild 29 Jun 2018 Fascia, Gutter, Lower roof 05 Jul 2018 Re: Building with Wisdom Homes 11394Jul 02, 2018 7:46 pm GLO Chinoandbebe GLO Congrats! What did you build an when did your slab go down? Awesome, so it only took 8 months to build! Re: Building with Wisdom Homes 11395Jul 02, 2018 7:51 pm Jenifermarie Chinoandbebe We have Handover tomorrow!!! Can't wait!!! Finally! Congratulations. Good luck with moving and settling in. Hope everything goes smoothly for you. Building Wisdom Aspiration 31 at Willowdale https://ourwillowdalehome.wordpress.com/ Re: Building with Wisdom Homes 11396Jul 02, 2018 7:56 pm Chinoandbebe GLO Chinoandbebe [quote="GLO"]Congrats! What did you build an when did your slab go down? Awesome, so it only took 8 months to build! [/quote]That sucks. What's ur overall impression on the build and anything that we should look out for that they need to fix for urs? Re: Building with Wisdom Homes 11397Jul 02, 2018 7:58 pm Jenifermarie In the chaos of this week I forgot to post an update here. We had an inspection this week to check all our rough ins for electrical and AC. It was really nice just to meet our SS to be honest. We picked up a few power points in the wrong spot which have been fixed up since. The electrician only had a print out of the electrical plan so some of the measurements of above/inside vanity for the bathrooms weren’t readable unlike on the electronic PDF. Everything on site is looking good although I failed to get many interesting photos because I was too busy trying to document where all my wires were running! Our lower roof is in at the back, although we’re still missing the garage part of the lower roof. Kitchen bulkheads have also gone in Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ And our stacker doors are in place...lockup is coming! Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ We had an inspector go through too and he picked up a few minor issues with straightening a wall, fixing a pipe and a couple of floor trusses that needed extra fixing to the frame. Pretty minor stuff. Our SS sent over some update photos today to show the remediation work...so happy to see all that soundscreen insulation! Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Gyprock was due to start today, originally it was scheduled on Wednesday but it was bumped back a couple of days for the remediation work. Building Wisdom Aspiration 31 at Willowdale https://ourwillowdalehome.wordpress.com/ Re: Building with Wisdom Homes 11398Jul 02, 2018 8:20 pm psur2357 Hi guys we upgraded the standard carpet areas to timber and found that at areas where timber meets tiles or timber meets stair carpet the floorer installed a silver coloured trimming pieces. We dont like this colour and I believe that they can get trimming pieces similar colour to the timber. Certainly bunnings offer a few colour options. Anyone got any experience in this? see photos below. thank you. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ I enquired about getting a better colour to match our floorboards but Di Lorenzo said silver was the closet match. I have found a store than can order us in a matching colour but we'll have to change it ourselves. I think it's been glued down so it might be a bit of a challenge to change. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Building with Wisdom Homes 11399Jul 02, 2018 8:42 pm becks81 Re : electrical consult. If we want downlight provisions and outdoor flood light provisions, what exactly do they do and what will we need to purchase on our end? We will probably get WH to install some of our lighting but not all of it. And what is the consensus about downlights in bedrooms? We just plugged them all in on the weekend & they are perfect! SO easy to do... Re: Building with Wisdom Homes 11400Jul 02, 2018 9:55 pm doosra Chinoandbebe GLO [quote="Chinoandbebe"][quote="GLO"]Congrats! What did you build an when did your slab go down? Awesome, so it only took 8 months to build! [/quote]That sucks. What's ur overall impression on the build and anything that we should look out for that they need to fix for urs? [/quote]Overall impression hmm...that's a hard one. We've definitely had our ups & downs. Knebel Kitchens have been amazing! We had an issue with some Scotia accidently being installed around our island bench & cupboards, but Knebel got it sorted quickly & kept me informed when replacing all the kickboards & back panel. They did a great job fixing it too. I'm very happy with how our kitchen turned out! It's ashame that some tradies just don't seem to care, which is disappointing & a let down. Some seem to lack common sense too. I would definitely suggest getting a Building Inspector, it's well worth it in my opinion. I used Jim's Building Inspector. My guy was very thorough. Try & have regular walk throughs with your SS, & know your plans & upgrades. That way you can pick up on anything that looks wrong or is missing before it becomes a real issue. Take lots of photos of your build during the different stages. You will use them as reference. Good luck! Can someone please offer some advice? Im DESPERATE. Because I'm completely and utterly exhausted. How long are variations taking with other companies at the moment? We… 0 18435 In fairness nobody gave a crap about the ACCC and the gag clauses continued in the pro forma templates of a few other builders after the ACCC took on Wisdom, and more… 19 73284 Hi Everyone, I am exploring builder in NSW and received a very tempting quote from Wisdom home for their momentum series. I just want to know experience of building… 0 8207 |
