Browse Forums Building A New House Re: Concrete Tilt panel home build - Brisbane 4Jun 16, 2018 8:24 pm Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Concrete Tilt panel home build - Brisbane 6Jun 17, 2018 6:48 am Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Concrete Tilt panel home build - Brisbane 8Jun 17, 2018 8:09 am Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Concrete Tilt panel home build - Brisbane 10Jun 17, 2018 9:57 am Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Concrete Tilt panel home build - Brisbane 14Jun 26, 2018 7:28 am Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Concrete Tilt panel home build - Brisbane 15Jun 26, 2018 8:35 am Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog Re: Concrete Tilt panel home build - Brisbane 18Jun 30, 2018 10:27 am alexp79 This house to build $1.2M? Which reality are you living in? $600K absolute max. Even after you spend $150K on your windows, although my estimate is well below $100k even if you go double glazing with the right vendor. What is your maximum sliding door span? Probably 6 m or so? You don't need anything expensive to hold your roof and act as your lintels - just properly reinforced concrete belt will do the job, this is uber cheap. I doubt you would even need galvanised beams here unless you plan to make them a feature of some kind. They are awful when it gets to thermal insulation as they will be acting as a thermal bridge, so suck big time on the external walls. ICF with 4 bars of reo and concrete pour on top should do the job. You roof is almost weightless. Owners are asking $1.3 million for the whole property for 40 acres. I heard it cost 500k to build the house. Conventional house with steel frame is much cheaper and you would get much more bang for your buck, right ? Just tilt panel concrete minus the steel beams would be cheaper too and as suggested , beams are a rather pain in the arse when it comes to insulation. Re: Concrete Tilt panel home build - Brisbane 19Jun 30, 2018 7:32 pm alexp79 This house to build $1.2M? Which reality are you living in? $600K absolute max. Even after you spend $150K on your windows, although my estimate is well below $100k even if you go double glazing with the right vendor. What is your maximum sliding door span? Probably 6 m or so? You don't need anything expensive to hold your roof and act as your lintels - just properly reinforced concrete belt will do the job, this is uber cheap. I doubt you would even need galvanised beams here unless you plan to make them a feature of some kind. They are awful when it gets to thermal insulation as they will be acting as a thermal bridge, so suck big time on the external walls. ICF with 4 bars of reo and concrete pour on top should do the job. You roof is almost weightless. 200% agree on $600k absolute max if done right & keep the simplicity of this design. I did a Google reverse Image search for the main photo of the front elevation & found the floor plan for this house. It is only 203sqm in size & all straight walls so would be very simple to build & glazing should be non factor as widest sliding door seems to be only 5.9M wide specially if you've got them opening Left & Right from the middle with other 2 panels being fixed. I've just ordered a 6200 wide bi-fold door & 6200 wide fixed window above (4 fixed panels within the frame ) without any issues in size - just needed to put a universal beam into the concrete above the door. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Concrete Tilt panel home build - Brisbane 20Jun 30, 2018 8:00 pm PS. Theres a similar type/layout pavillion build concrete house down in Margaret River in WA. Check it out here https://www.airbnb.com.au/rooms/14808665 Hello Josh, This is Irving from PRIMA, we are a manufacturer of the staircase, railings, kitchen cabinets, windows, doors from China. If you have requirement to purchase… 0 5454 Hi, does anyone have a clue how the Brisbane Development website work in terms of how uptodate the dates on it are (developmenti.brisbane.qld.gov.au). I transfered… 0 4623 |
