https://1drv.ms/f/s!AoKBYVes8JAPjTu-QGBikZCk-1De
Browse Forums Building A New House Re: Building at Bardia - New Breeze 788Jun 14, 2018 3:14 pm Building Wentworth 33 CDC lodged to Council : 22 June 2018 Site excavation 31 July 2018 Slab 08 Aug 2018 Frame 22 Aug 2018 Roof 10 Sep 2018 Brick 24 Sep 2018 Re: Building at Bardia - New Breeze 796Jun 17, 2018 12:59 am Cooky GLO Sounds very nice! What height ceilings are you doing on Ground Floor. I have read that there is a 6m from boundary for rear balcony which I satisfy. But I have also read a 12sqm limitation if balcony is above 3000mm height above natural ground level. Yes, thats right with the 6m. I thought you were stretching the house as far back as you could. The ground floor height is 2.7m so i will re check your advice to make sure we get it. Allcastle homes seem to have been allowed to do their displau homes like that withthe full stretched balcony in edmonson park so i presume we should be okay but you never know! My ground floor is the same so I’m keen to see if I can get it through like you. Double check. If I was to get the regular rear balcony off the master it would be approx 5m x 4m Re: Building at Bardia - New Breeze 800Jun 20, 2018 4:06 pm GLO Cooky GLO Sounds very nice! What height ceilings are you doing on Ground Floor. I have read that there is a 6m from boundary for rear balcony which I satisfy. But I have also read a 12sqm limitation if balcony is above 3000mm height above natural ground level. Yes, thats right with the 6m. I thought you were stretching the house as far back as you could. The ground floor height is 2.7m so i will re check your advice to make sure we get it. Allcastle homes seem to have been allowed to do their displau homes like that withthe full stretched balcony in edmonson park so i presume we should be okay but you never know! My ground floor is the same so I’m keen to see if I can get it through like you. Double check. If I was to get the regular rear balcony off the master it would be approx 5m x 4m For a rear balcony, you have to put in a privacy screen if your balcony will be 3 m above ground level. For reference, this is the Austlii reference. My take on this is, that they would be breaking the law denying access to a homeowner in Victoria, or their agent from having… 1 9094 Is it just a report written to give to the bank initially and it is based on what and how your payments are made up for, or is it a full service where they go out and… 2 5599 Hi Suku18 In NSW the statutory required insurances are: 1. HBCF ( Home Building Compensation Fund) - This is if the builder dies or goes broke. But this only covers 20%… 1 2712 |
