Browse Forums Bathrooms and Laundry Re: HELP! *** How to remove this towel rail? *** 4Jun 15, 2018 1:48 pm I'd just get a hacksaw and cut off the broken part of the railing, then the silver and cap part will slip off. Looks like you'll have to do that to remove the others as well. I'd cut them as opposed to using a hammer so you don't pull the screws out of the wall. Re: HELP! *** How to remove this towel rail? *** 5Oct 21, 2018 3:17 pm Hi. Great photos!! I have exactly the same plastic towel rail as you in my two bathrooms (house is about 18 years old). One of the handrails has been pulled away from the wall by a few mm so I want to repair the handrail. I have spent hours trying to get the large circular cover off by turning and pulling the cover and by pressing the tab up and down. All I managed to achieve is breaking off one of the tabs. Have you by any chance managed to solve this problem? Not a Handyman. Western Australia Re: HELP! *** How to remove this towel rail? *** 6Nov 06, 2018 11:11 am I found this forum while trying to remove the same towel rail, I hacked at the round bit with a saw then it was just a matter of unscrewing the screw, Re: HELP! *** How to remove this towel rail? *** 7Nov 06, 2018 11:13 am jodiegethejobdone I found this forum while trying to remove the same towel rail, I hacked at the round bit with a saw then it was just a matter of unscrewing the screw, And those little tag things are completely useless they are moulded to the rail and serve no purpose other then to provide false hope it will be a simple removal Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: HELP! *** How to remove this towel rail? *** 8Apr 24, 2019 5:19 pm My husband just had the same issue with the same towel rail in our bathroom. The plastic tab tag thing has nothing to do with getting it off the wall. What he did was use a bread and butter knife to pop out the chrome dress ring out and away from the plastic cup. He then slipped the knife between the gyprock and the plastic cup to pop off the mounting wall bracket, taking care not to damage the gyprock. The key is in the dress ring and sliding it off the cup. Electrical just got back to me and said the most they can provide is a single power point on the Bedroom 1 side of that wall. After handover, your towel rail installer… 2 3847 Please suggest a solid quality swivel bar towel holder in bathrooms & bedrooms from… 0 3122 How do you remove one of these ceiling air con vents? And is it possible to disconnect the duct joined to the vent from inside the house, without going into the roof cavity? 0 5933 |
