Browse Forums Paving & Concreting Re: Timber stains on concrete...HELP! 5Dec 01, 2011 5:09 am Landscape Design & Construction http://cherub.squarespace.com/ Re: Timber stains on concrete...HELP! 9Dec 04, 2011 9:26 am Where you are coming from is where you are going to... Re: Timber stains on concrete...HELP! 10Dec 04, 2011 10:50 pm Accessible Carpentry & Cabinets accessiblecarpentry@gmail.com accessiblecarpentry.com.au https://www.facebook.com/pages/Accessible-Carpentry-Cabinets/583314911709039 Re: Timber stains on concrete...HELP! 13Jun 13, 2018 8:21 am Tanin stains are Best removed with oxalyc acid. This is what timber coating products use as a prewash to remove the tannins as a base agent. It used to be called “oxalyc acid” by diggers in Bunnings. It’s now called “rust and stain remover”. Still made by diggers. It comes in a powder/granular form which you mix with water. Wet down surface to clean. Apply mix (use bucket and brush). Leave for 10 mins then thoroughly rinse with water. Repeat if necessary. ive been doing this successfully for 20 years. Re: Timber stains on concrete...HELP! 14Jun 30, 2018 3:51 pm ssvetec Hey, So I had some treated pine delivered for some landscaping. I parked the timber on the exposed ag concrete around the back. A few days later...it pretty much rained from 8am to 7pm. Now I have timber stains all over the concrete. How can I/what can I do or use to get rid of these stains? If I don't, the missus will probably kill me considering the concrete is barely 3 months old. Thanks in advance. Hey mate, Did you manage to get the stains out?? I’ve got the same issue, have tried Oxcylic acid but it’s still there Clarendon Denton 24 | Gold Coast Status: Internal fitout! ETA: April 2018 Hi everyone, Have just put a shower in the laundry and after only using it 2-3 times have noticed staining on the grout. The tiles were glued onto a concrete wall after… 0 5516 Engineering timber is certainly a less fuss option, times cheaper to supply and install and better withstands humidity. 1 16117 Sam There is a much stronger glue than liquid nails. It's called T Rex and will stick your timber to the concrete. Cheers Simeon 1 1663 |
