Browse Forums Building Standards; Getting It Right! Re: Concrete path tilted (Metricon build) 3Jun 12, 2018 8:18 pm steve.li.xin Thanks for the photo But it appears that the slab edge requires support & Edge retaining... do you have your site plans with levels? You is responsible for retaining in your contract? Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Concrete path tilted (Metricon build) 4Jun 12, 2018 8:33 pm StructuralBIMGuy @steve.li.xin Thanks for the photo But it appears that the slab edge requires support & Edge retaining... do you have your site plans with levels? You is responsible for retaining in your contract? Re: Concrete path tilted (Metricon build) 5Jun 12, 2018 8:42 pm sweetswisssteel StructuralBIMGuy @steve.li.xin Thanks for the photo But it appears that the slab edge requires support & Edge retaining... do you have your site plans with levels? You is responsible for retaining in your contract? How can you tell from that photo? Just curious, I am building soon and would like to know what you are referring to. Thanks From the photo I can't see any support/retaining beneath the porch slab the soil appears to have eroded? also It needs to be highlighted and checked, Thanks Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Concrete path tilted (Metricon build) 6Jun 13, 2018 12:17 am bestspecials You need for the water to run away from the house so it needs to slope away. Our outdoor area is the same so the water doesn't pool next to the house. Hey bestspecials- Just as I like to learn. Does your path slope parallel with your pool house ......possibly towards a drain? or outwards away from your pool house.... or both. Steve, someone will be able to tell you the tolerances for concrete pathway levelness if you are still concerned. These below may be of interest if you want more information about your SS’s explanation. https://www.qbcc.qld.gov.au/sites/defau ... 20Home.pdf Vol 2 NCC 2016 Building Code of Australia - 3.1.2.3 Surface water drainage Surface water must be diverted away from Class 1 buildings as follows: (a) Slab-on-ground — finished ground level adjacent to buildings: the external finished surface surrounding the slab must be drained to move surface water away from the building and graded to give a slope of not less than (i) 25 mm over the first 1 m from the building in low rainfall intensity areas for surfaces that are reasonably impermeable (such as concrete or clay paving); or (ii) 50 mm over the first 1 m from the building in any other case. Re: Concrete path tilted (Metricon build) 7Jun 13, 2018 7:18 am Gaudi bestspecials You need for the water to run away from the house so it needs to slope away. Our outdoor area is the same so the water doesn't pool next to the house. Hey bestspecials- Just as I like to learn. Does your path slope parallel with your pool house ......possibly towards a drain? or outwards away from your pool house.... or both. Steve, someone will be able to tell you the tolerances for concrete pathway levelness if you are still concerned. These below may be of interest if you want more information about your SS’s explanation. https://www.qbcc.qld.gov.au/sites/defau ... 20Home.pdf Vol 2 NCC 2016 Building Code of Australia - 3.1.2.3 Surface water drainage Surface water must be diverted away from Class 1 buildings as follows: (a) Slab-on-ground — finished ground level adjacent to buildings: the external finished surface surrounding the slab must be drained to move surface water away from the building and graded to give a slope of not less than (i) 25 mm over the first 1 m from the building in low rainfall intensity areas for surfaces that are reasonably impermeable (such as concrete or clay paving); or (ii) 50 mm over the first 1 m from the building in any other case. Gaudi, very appreciate for the link. It looks weird, but at least, I can accept it if it is not a construction problem. Re: Concrete path tilted (Metricon build) 8Jun 13, 2018 8:24 am Gaudi bestspecials You need for the water to run away from the house so it needs to slope away. Our outdoor area is the same so the water doesn't pool next to the house. Hey bestspecials- Just as I like to learn. Does your path slope parallel with your pool house ......possibly towards a drain? or outwards away from your pool house.... or both. Steve, someone will be able to tell you the tolerances for concrete pathway levelness if you are still concerned. These below may be of interest if you want more information about your SS’s explanation. https://www.qbcc.qld.gov.au/sites/defau ... 20Home.pdf Vol 2 NCC 2016 Building Code of Australia - 3.1.2.3 Surface water drainage Surface water must be diverted away from Class 1 buildings as follows: (a) Slab-on-ground — finished ground level adjacent to buildings: the external finished surface surrounding the slab must be drained to move surface water away from the building and graded to give a slope of not less than (i) 25 mm over the first 1 m from the building in low rainfall intensity areas for surfaces that are reasonably impermeable (such as concrete or clay paving); or (ii) 50 mm over the first 1 m from the building in any other case. I meant pool as in puddle near the house. Our outdoor area is completely covered and has a gentle slope that is barely noticeable. The house plans show a 20mm fall from the wall to the edge of the concrete. It will be tiled once building is finished. Re: Concrete path tilted (Metricon build) 9Jun 16, 2018 2:32 pm bestspecials I meant pool as in puddle near the house. Our outdoor area is completely covered and has a gentle slope that is barely noticeable. The house plans show a 20mm fall from the wall to the edge of the concrete. It will be tiled once building is finished. Sorry for misunderstanding. Nice to hear that the builder had already graded the ground away from your foundation before tiling. The brickwork and mortar lines in Steve’s pic shows the porch ?graded or not level along its length parallel with the house. Hello everyone, After some suggestions and ideas about how to put a concrete path around the drop edge beam area on our new build. We are required to have a concrete path… 0 12875 Thank you so much for your response. I have drawn a pedestrian gate in - for curb appeal, let's see how much costs come in at. I think you're right - if we decide to… 2 6536 Hi all Following the recent heavy rainfall in Sydney, I am keen on redirecting water away from the house's base as much as… 0 6793 |
