Browse Forums Building A New House Re: Advice on house plans 6May 23, 2018 10:07 am Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Advice on house plans 10Jun 10, 2018 3:39 pm arcadelt mummy1 So this is what the first proper draft looks like. Trying to be helpful and constructive here, but since you made no changes based on previous comments, I wonder if you a completely fixed on your original floor plan. That said, given that the floor plan is really only 50% of the design, perhaps you could post up some the elevations so we can see what design elements have been incorporated to compensate for the poor orientation of the floor plan. No elevations as yet, and no not "completely fixed" on anything. The block is sloping, approx., 6 meters fall from south (high point) to north, over 70 meters. We also need to consider flow to the rear as we have no rear neighbour with a reserve joining our land. Want to advantage of this. Not fans of kitchen at the front of the house. The floor level will probably be 3 meters above street, coming to flat ground at the rear. Really tight at the top of the stairs- how to get furniture into those rooms? Study books - does anyone really use them these days? Large storage closet would be more functional. 2 6890 Versaloc is a mortarless besser block system that still needs a properly engineered footing. If you just do a 400x200 footing it will fail in time. At 17m long you need it… 1 18082 Ask the council if there is a chance of getting build over easement exemption. Sometimes easements are unused and 24cm is not all that much. Good luck. And yes any builder… 2 13775 |
