Browse Forums General Discussion Re: Starting new build from scratch. Mernda Sloping land 3May 29, 2018 8:04 am Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Starting new build from scratch. Mernda Sloping land 4May 29, 2018 8:34 am alexp79 You can also consider Dincel for your retaining walls - it has a lot of advantages, does not require waterproof and generally comes super cheap in comparison to anything else. The only additional investment will be render, stone or paint finish for it. As an Engineer I am skeptical of Marketing Spin and of Companies that don't put up Details, Calculations & Costs. Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Starting new build from scratch. Mernda Sloping land 5May 29, 2018 11:15 am StructuralBIMGuy alexp79 You can also consider Dincel for your retaining walls - it has a lot of advantages, does not require waterproof and generally comes super cheap in comparison to anything else. The only additional investment will be render, stone or paint finish for it. As an Engineer I am skeptical of Marketing Spin and of Companies that don't put up Details, Calculations & Costs. Dincel as a company is well known in industry and has very serious reputation. All the necessary engineering details and detailed costs comparison is readily available from their Web site. E.g. here: https://www.dincel.com.au/site/DefaultS ... -Walls.pdf Re: Starting new build from scratch. Mernda Sloping land 6May 29, 2018 4:11 pm You are comparing Residential construction Class 1 with multistory apartment construction ? Residential Masonry 2c -90mm Bricks (20 bricks/m2) M&L, Costs < $45/m2 hth Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Starting new build from scratch. Mernda Sloping land 7May 30, 2018 1:49 am Hi its.just.sharon, What direction does the block face? You're lucky, & have a nice wide frontage. This should mean that you should be able to build a week orientated house that is not overshadowed by neighbours. Getting the orientation of your home right plays a large part in increasing comfort while reducing energy bills. Generally you want your living areas (& a large proportion of your glazing) to face north, minimising western windows. This is called passive solar design. You can read more about it here, http://yourhome.gov.au/passive-design/orientation Re: Starting new build from scratch. Mernda Sloping land 8May 31, 2018 10:21 pm ddarroch Hi its.just.sharon, What direction does the block face? You're lucky, & have a nice wide frontage. This should mean that you should be able to build a week orientated house that is not overshadowed by neighbours. Getting the orientation of your home right plays a large part in increasing comfort while reducing energy bills. Generally you want your living areas (& a large proportion of your glazing) to face north, minimising western windows. This is called passive solar design. You can read more about it here, http://yourhome.gov.au/passive-design/orientation Hi, the house will be east facing, with minimal windows on the north side. we have decided to use double glazing in commercial frames. Hoping the house will be extremely efficent when it comes to heating and cooling. I see the main draw back in the ceiling height down stairs as we have decided to go 3 metre and up stairs 2.55. Generally, the texture that you listed will have a 2mm size stone chip in it which is dragged with float to give the lines Any patch work needs to be 2mm less than face… 2 1835 Howdy all. I am looking for feedback on what people would do to maximise and make an area as flat as possible. First, out the front of the house is a sloping hill, pretty… 0 20289 |
