Browse Forums Building A New House Re: Quality of Package Homes 7May 23, 2018 8:15 pm Great posts from everyone. I have said this before "quality is a function of price" with a proviso that you can pay for quality and still get crap. No one has ever found a way to deliver Mercedes Benz quality at the price of Tata and that is universally true for all economy. What project builders have worked out is that building cost per sq metre diminishes with size and building volume even more so. So they packaged biggest bang for your buck and once reached serious volume then made a killing on market volume and market power. Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog Re: Quality of Package Homes 9May 25, 2018 6:56 am Joker Its depends on builder, speak to their tradesman and local suppliers, I use to discount builders whom placed outside stud walls 600mm apart, has in my experience better builders used, 450 mm stud wall gaps, as its something no body sees, but was important to me, I picked builder tradesman on whats under the wall and their attention to detail, I questioned and found out who cared about quality by learning about the building industry, the more you learn, the better, knowledge is power to a better build. Does anyone knows if Rawson Homes uses 450 or 600mm stud walls? Thanks Re: Quality of Package Homes 12May 25, 2018 3:01 pm Steeden I couldn't work out for ages why the top one looked funny Re: Quality of Package Homes 14May 25, 2018 6:25 pm kirashogun Volume builders will save every penny especially for things you don’t see. Nobody specifies posistrut floor joists as part of the spec or know what it even is. However that is not to say all volume builder’s house is crap. Some of the quality can be as good as custom but it’s just not consistent. That’s the key. If you are lucky you will get quality, if not you might get slab heave instead. Custom builder also allow wild designs and features that no volume builder will touch. Basement car parks, home lifts, curved walls, glass bricks, anything you can imagine. Again it all come down to budget. Quality wise. You will get between 50-95% quality for 2/3rd of the cost of custom with a volume builder where as you will get 85-100% quality for 40% more cost of a volume builder. My biggest concern at the moment is the extensive use of waffle slabs. A lot of volume builders don’t give you the choice of another slab design even if you are willing to pay. It’s waffle or too hard bucket, go somewhere else. Using 450m centres, posi-strut, over-engineered/specified everything because why take a risk? I ended up using 412mm Posi's to run ductwork and because it's stronger too. My question is, what cheaper option to posi-strut is there? It never occurred to me there was one. Re: Quality of Package Homes 15May 25, 2018 7:11 pm JB1 kirashogun Volume builders will save every penny especially for things you don’t see. Nobody specifies posistrut floor joists as part of the spec or know what it even is. However that is not to say all volume builder’s house is crap. Some of the quality can be as good as custom but it’s just not consistent. That’s the key. If you are lucky you will get quality, if not you might get slab heave instead. Custom builder also allow wild designs and features that no volume builder will touch. Basement car parks, home lifts, curved walls, glass bricks, anything you can imagine. Again it all come down to budget. Quality wise. You will get between 50-95% quality for 2/3rd of the cost of custom with a volume builder where as you will get 85-100% quality for 40% more cost of a volume builder. My biggest concern at the moment is the extensive use of waffle slabs. A lot of volume builders don’t give you the choice of another slab design even if you are willing to pay. It’s waffle or too hard bucket, go somewhere else. Using 450m centres, posi-strut, over-engineered/specified everything because why take a risk? I ended up using 412mm Posi's to run ductwork and because it's stronger too. My question is, what cheaper option to posi-strut is there? It never occurred to me there was one. HY Joist is typically what project builders use. Pryda Longreach is the other one but they are dearer as it uses a lot more wood. Lots of other options. Re: Quality of Package Homes 17May 26, 2018 11:01 am I totally forgot about the hy-joist. Very impractical. I bet a lot of them have massive holes in them to run sewerage and air ducting. I only remembered the old style hardwood beams. I suppose everything is built to a price. Better to build a 10% smaller place but higher quality than spend the same amount on a larger but lower quality IMO. Re: Quality of Package Homes 18May 26, 2018 2:33 pm Steeden Not termite treated? This is in Victoria not NSW so environment and regulation is different. Ask for references and speak to them. If they are defensive or try to avoid the request, walk. 1 76605 I would never build with Fowler homes. I built with them in 2021 and till date maintenance issues are pending. All their existing trades and businesses don't work with… 14 107226 Hi there! Putting the feelers out there for those who have (or almost) built with Arli homes! Interested in your experiences who've built from their stock home designs… 0 25113 |
