Well it's hard to tell if it's N1 from those few photos?
Now you also have to deal with 8 Tonnes of roof tiles
with failing Truss Connections.
Browse Forums General Discussion Re: Slab heave is alive and well, watch out. 41May 22, 2018 11:49 am Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Slab heave is alive and well, watch out. 57May 23, 2018 2:07 am 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Slab heave is alive and well, watch out. 58May 23, 2018 3:01 am No all i gevin was a little booklet stating how to look after your new home. It had 3 pages that's all. Re: Slab heave is alive and well, watch out. 59May 23, 2018 3:07 am I have posted on here the BTF 19 AND BTF 22 please do read it thus is what builders don't want you to know, that a builder is responsible its called the the builders guide to preventing Dwelling damage. They hand you over the BTF 18 which is the home owners guide. But what about the BTF 19 and BTF 22. Its aimed specially to builders which holds them accountable for a lot of things. Please let me know your thoughts about the BTF 19 AND BTF 22. Thanks in Advance. Re: Slab heave is alive and well, watch out. 60May 23, 2018 8:10 am Just be aware that Guides are not leglislated and not always accurate even though they are invariably based on regulations. Everything needs to be cross referenced with applicable regulations for accuracy and currency. 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. It's possible but a soak well is usually much larger. Your 'soak well' only holds 424 litres when full. What is your soil type? Soak wells need sandy soils. 10 9125 Finally got the Soakwell at my house sucked out. Now I’m looking for ideas on how to hide it as it’s a bit of an eye sore. I’m thinking I’d like to turf over the… 0 3684 Firstly the ableflex that has been installed needs (manufactures specification) a sealant cap over the top, preventing water draining down between the slab and the… 3 7880 |
